| View previous topic :: View next topic |
| Author |
Message |
Total Words: 692,619
Reputation: Highly regarded
Posted: Tue Feb 10, 2004 1:34 am Post subject: Gyroscopic Propulsion Device |
I feel that if a mechanical device can produce a thrust, then the reverse may also be true and a similar device might be able to harness gravitational thrust. Here are pictures from US patent 4,784,006 which says it produces a propulsion force when rotated.
| Description: |
| Filesize: |
16.58 KB |
| Viewed: |
851 Time(s) |
| Description: |
| Filesize: |
14.9 KB |
| Viewed: |
895 Time(s) |
Jonathan
Total Words: 229,845
Reputation: Well respected
Posted: Tue Feb 10, 2004 3:53 am Post subject: re: Gyroscopic Propulsion Device |
I've seen this before! I'll have to go look at the patent, but I rememeber coming to the conclusion that it only seems like it would do something, and that in fact it wouldn't produce a thrust or run powered by gravity (if you put a barrier in the way so that it was off set to the side rather than downward).
EDIT
I went to look at the patent and I can't get the pictures to come up, but I read it and I think I get it. I might be able to fiddle with a model of it tonight. Also, I think you are right, if inertial propulsion is possible then so too is PM.
EDIT2
I finished that model, and I'm not very impressed with it so far. It's not wonderful, it's a little unbalanced, but not from the weights. Because I don't have any springs on hand, I used rubber bands, and one seems to have been exposed to heat at some point, because it doesn't stretch exactly the same as the others. Also, I couldn't get an optimal ratio between the sizes of the flywheel radius and rubber band length, so I had to opt for a wheel that is a little big for the rubber bands, and even with the weights on it, it doesn't sag very far. I'll see if I can find a replacement rubber band, but I don't think it will effect the performance much.
_________________ Disclaimer: I reserve the right not to know what I'm talking about and not to mention this possibility in my posts. This disclaimer also applies to sentences I claim are quotes from anybody, including me.
Total Words: 29,971
Reputation: Disregarded by some
Jonathan
Jonathan
