Stronger vision of imbalanced
Leafy
Post by Leafy »
I feel like I have to make it up.
Here we have a mass spring system drop 1/4 circle.
If we attached a small weight to the big weight, the torque profile have greatest dip at the bottom.
If we wired the small weight with pulley and strings. The torque profile is greatest on the side.
iacob alex
Re: Stronger vision of imbalanced
Post by iacob alex »
Hi Leafy !
Take a look about “half pipe skateboarder’s physics” ,then play his performance….with his mechanical equivalence ( elastic/spring mass pendulum ).
With a spring you can play/add and release …the rotational inertia
Al-ex
Leafy
Post by Leafy »
Thx Alex
Just want to make the remark , the amount of creativity around this subject never ends.
Leafy
Post by Leafy »
It comes in pairs of weights.
One moves closer to the center the other moves further from the center.
They takes turn gravitating each other.
They barely move with one crossbar.
Leafy
Post by Leafy »
When configured 3 pairs of weights, it looks familiar.
Leafy
Post by Leafy »
By adding 4 stoppers mid way, one way net torque is achieved. This wheel should turn counterclockwise.
Leafy
Post by Leafy »
There seems to be a longer imbalanced on one side than the other
Leafy
Post by Leafy »
Never mind, they seems balanced. I now believe conservation of energy is there for a reason. It might be possible, but I decide not to tamper.
Leafy
Post by Leafy »
Vertical ramp. Maybe
Hi
Is this what you are thinking about?
Ho do not worry on breaking any conservation rules.
An accelerating device has access to an energy source that has lots to spare.
Leafy
Post by Leafy »
Exactly Agor95 :)
Pulling strings on roller
Leafy
Post by Leafy »
Roller ramp mix
Leafy
Post by Leafy »
8 oil drops with a twist.
Connect strings from one roller to another
