John Collins wrote: Actually that's not true, I don't envy you, because I believe with more than faith, that gravity will turn out to be the prime source of energy for Bessler's wheel.
Gravity is not a source of energy, John. That's why it's impossible and none of your wheels have ever rotated. It could be said that gravity is a one-way force that participates in the transformation of energy. But not as a source, an origin, of energy. Nearly all of our energy sources trace their origin back to the sun.
This is not a complex subject, Daxwc. Like 197sv said, you can make it as complex as you want and bring up more contemporary thoughts on gravity; is it just a warp of space-time around a mass; how does it propagate through that space; the difference in the calculation of how much light is deflected between Newton's formula and general relativity formulas, but that doesn't change the very simple, verifiable local effects it has on wheel-and-axles.
The Eotvos effect is toward the center of the earth flying in a westward direction; Grimer's post only shows the eastward.
11Turion: You said on page 2 you already know your build doesn't work, but did the build help you understand why it didn't work? And, if two didn't work, why do you think that adding more of them will make it rotate? If it helps, I can say that adding more will just make it heavier; it won't work for the same reason that two of them didn't work.
I ran across this today; I wonder if you made one so the riders could push their seat with their legs, it would turn the Ferris Wheel from the imbalance; no motor required. But I guess no one would want to pay to ride on it! Well, my daughter maybe!
http://en.wikipedia.org/wiki/Ferris_whe ... ric_wheels
