| View previous topic :: View next topic |
| Author |
Message |
pequaide
Total Words: 161,352
Reputation: Acknowledged
pequaide
pequaide
pequaide
pequaide
pequaide
Total Words: 117,115
Reputation: Well respected
Total Words: 694,399
Reputation: Highly regarded
pequaide
Posted: Wed Feb 15, 2012 2:24 am Post subject: re: energy producing experiments |
I am now throwing with 380 grams of drive on the 12 inch diameter while throwing a 98 gram missile from the 18 inch diameter. The tether is a full wrap of the circumference. The missile lifts above the machine as the tether unwinds but its maximum velocity is down and into the floor. This downward direction is determined by where the missile first lifts from the surface of the 18 inch wheel. To change the direction I will have to use a mechanical release. But I will not be able to do that until the throws can be done outside. Down is the best way to throw in the lab anyway.
The velocities into the floor are reasonably violent. It is far more violent than the overhead velocity, it violently accelerates into the ground. The wheel does not stop, which means there is even more motion left in the wheel. Possibly the missile thumps the ground before it secures all the motion of the wheel. I am reasonably certain that this is a decent throw but in the wrong direction. And it is done with little mass difference; 380 at 12 and 98 at 18.
I also used the double wheel as an Atwood's again. I put 1.262 kilograms on both sides at the, little over, 12 inches diameter. Then I balanced one side and then the other side with masses at the, just under, 18 inch diameter. This gave me two masses of .88 kilograms on each side at the larger diameter. Both of the (2 * 1.262 at 12 and .88 * 2 at 18) arrangements would accelerate through half a rotation in 3.72 seconds. The drive mass in both arrangements was only 68.3 grams at the 12 inch diameter. This is a lot of motion for only 68.3 grams dropped .48 meters.
This; only 68.3 grams dropped .48 meters, inspired me to try a low mass difference, slow throw.
You need some speed to make a vertical throw because the missile simply falls off the wheel before the motion of the wheel can catch it. Then the missile is dangling as a pendulum when the wheel tries to pick it back up, I just does not work.
But the 68.3 grams gives you .25 m/sec at 12 inches, and it seems like that is getting close to throw-able. Anyway that is why I tried the 380 g / 98 g throw.
pequaide
nicbordeaux
Total Words: 211,152
murilo
Total Words: 155,188
Reputation: Appreciated
pequaide
FunWithGravity2
Total Words: 154,602
Reputation: Respected
Posted: Tue Feb 28, 2012 10:10 pm Post subject: re: energy producing experiments |
close the loop, close the loop, close the loop, close the loop,close the loop, close the loop, close the loop, close the loop,close the loop, close the loop, close the loop, close the loop,close the loop, close the loop, close the loop, close the loop,close the loop, close the loop, close the loop, close the loop,close the loop, close the loop, close the loop, close the loop,close the loop, close the loop, close the loop, close the loop,close the loop, close the loop, close the loop, close the loop,close the loop, close the loop, close the loop, close the loop,close the loop, close the loop, close the loop, close the loop,close the loop, close the loop, close the loop, close the loop,close the loop, close the loop, close the loop, close the loop,
_________________ Si mobile in circumferentia circuli feratur ea celeritate, quam acquirit cadendo ex
gravitati aequalem.
pequaide
