Forum Index
BesslerWheel.com
Discussion Board
Forum Index
If you were an inspector of Bessler's wheel
Page 1 of 2 Goto page 1, 2  Next
Post new topic   Reply to topic    Forum Index -> General Discussion
Author Message
justsomeone
Total Words: 48,501
Reputation: Well respected
Well respected
PostPosted: Mon Apr 16, 2012 2:14 pm    Post subject: If you were an inspector of Bessler's wheel Reply with quote Report Post to Admin
If 300 years ago, you were among the bright minds invited to inspect Bessler's 12 ft. wheel, is there anything you would have done that you suspect the others did not check? What else would you have noted?
_________________
Back to top
View user's profile
Wubbly
Total Words: 43,715
Well respected
PostPosted: Mon Apr 16, 2012 5:50 pm    Post subject: re: If you were an inspector of Bessler's wheel Reply with quote Report Post to Admin
Check the temperature of the wheel and the external stampers. Are they warmer than one would expect based on the ambient temperature?
While in operation, check for any unusual airflow patterns around the wheel indicating exiting air.
Back to top
View user's profile Visit poster's website
Total Words: 659,569
Reputation: Highly regarded
Highly regarded
PostPosted: Mon Apr 16, 2012 7:20 pm    Post subject: re: If you were an inspector of Bessler's wheel Reply with quote Report Post to Admin
Ask him to beef up the rim strength if needed & then take it off the supports - give it a gentle push & see if it will accelerate across a long level & smooth surface like a great hall floor - repeat again climbing a ramp.
As wubbly said, test the ambient temperature in the room & when the wheel is stopped after running a while insert a temperature probe inside the wheel thru the maintenance port & compare.
Back to top
View user's profile Skype Name
getterdone
Total Words: 40,533
Well respected
PostPosted: Mon Apr 16, 2012 7:28 pm    Post subject: re: If you were an inspector of Bessler's wheel Reply with quote Report Post to Admin
I would have given more detail about Bessler removing the weights/rollers from the wheel. The wheel was 12ft tall, did he have a step-ladder?
_________________
Back to top
View user's profile
DrWhat
Total Words: 88,230
Highly regarded
PostPosted: Mon Apr 16, 2012 9:34 pm    Post subject: Reply with quote Report Post to Admin
I would have noted down exactly what all the sounds were. And I agree, more details about the removed weights and I would have tried to determine from where and how he was removing the weights.
Back to top
View user's profile Send email Visit poster's website
Total Words: 925,820
Highly regarded
PostPosted: Tue Apr 17, 2012 5:28 am    Post subject: re: If you were an inspector of Bessler's wheel Reply with quote Report Post to Admin
I would talcum my wig put on my starched tights and say; " I will drink to that!".
Back to top
View user's profile Send email MSN Messenger
getterdone
PostPosted: Tue Apr 17, 2012 9:43 am    Post subject: re: If you were an inspector of Bessler's wheel Reply with quote Report Post to Admin
I just had a mental image of you in a wig and tights.....now I need a drink
Back to top
View user's profile
Unbalanced
Total Words: 63,372
Well respected
PostPosted: Tue Apr 17, 2012 5:53 pm    Post subject: re: If you were an inspector of Bessler's wheel Reply with quote Report Post to Admin
I'd kick Bessler square in the nuts and then run over and tear back the curtain, and copy the heck out of the thing and if it turned out to be a fraud, I'd go back over and kick him in the nuts once again.
Back to top
View user's profile
Total Words: 190,105
Well respected
PostPosted: Tue Apr 17, 2012 11:14 pm    Post subject: re: If you were an inspector of Bessler's wheel Reply with quote Report Post to Admin
He didn't have nuts; he had balls!
Big brass ones.
_________________
"Never argue with an idiot, because they will only bring you down to their level and beat you by experience."- John Guerrero
Wile E. Coyote - super genius; “I like the way that rolls out”
Back to top
View user's profile
Zogg420
Total Words: 623
Reputation: None
None
PostPosted: Tue Apr 17, 2012 11:43 pm    Post subject: re: If you were an inspector of Bessler's wheel Reply with quote Report Post to Admin
I would have asked to see more work added gradually claiming i wanted to see max capability but being more interested in the sound as rpm slowed.
Back to top
View user's profile
Alexioco
Total Words: 54,813
Reputation: Respected
Respected
PostPosted: Wed Apr 18, 2012 8:33 am    Post subject: re: If you were an inspector of Bessler's wheel Reply with quote Report Post to Admin
I think I would have asked as Fletcher said to see if the wheel could actually roll along a surface and even up an incline. Also if the wheel could be tilted horizontally with the axle now veritcal to see if it ran then. This would show whether the wheel required gravity at all or not.
Alex
_________________
"A great craftsman would be that man who can 'lightly' cause a heavy weight to fly upwards!..." (Page: 291)
Back to top
View user's profile
Total Words: 245,055
Highly regarded
PostPosted: Sat Apr 21, 2012 9:43 am    Post subject: re: If you were an inspector of Bessler's wheel Reply with quote Report Post to Admin
I think you would have to modify Fletch's suggestion to see if the wheel would roll along of its own accord. In winding tests the rope was wrapped around the axle and I think to do the rolling along test you would have to rest each side of the axle on rails to hold the rim of the wheel off the ground. Then you could test its ability to roll up hill even.
_________________
and see my video about Bessler http://www.youtube.com/watch?v=5BWVKtpuzn0
For all Bessler books http://www.free-energy.co.uk
Back to top
rickydog
Total Words: 909
Reputation: None
None
PostPosted: Sat Apr 21, 2012 10:30 am    Post subject: re: If you were an inspector of Bessler's wheel Reply with quote Report Post to Admin
I would try to find out where the noises where happening during rotation. Near 12 o'clock, 3 o'clock, etc., and, how close to the rim.
Were they a single noise or maybe a double, like a heartbeat?
Also, what happened when the box full of rocks was lifted as high as it could go, since the rope was tied off and wrapped around the axle. Did the wheel stop, then reverse due to the weight? Seems that his enemies would have used that against him. Why didn't he rig up a more continuously running demo for lifting weights?
I would have loved to see it powering a sawmill.
Back to top
View user's profile
Total Words: 692,808
Highly regarded
PostPosted: Sat Apr 21, 2012 1:12 pm    Post subject: Reply with quote Report Post to Admin
Bessler did rig up a more continuously running demo. He had a hammer mill and a water pump.
Back to top
View user's profile Send email Visit poster's website Skype Name
PostPosted: Sat Apr 21, 2012 5:41 pm    Post subject: re: If you were an inspector of Bessler's wheel Reply with quote Report Post to Admin
It is my belief as others here agree; the axle was used as a "capstan rope winch" requiring no more than three wraps of rope. The loose or whip end of the rope was manually tensioned engaging the winch. Once the load was raised the rope was relieved of tension and the rope would play out against the rotation of the axle allowing the load to be manually dropped back to ground level ready for a repeat.
Back to top
Display posts from previous:
Post new topic  Reply to topic    Forum Index -> General Discussion All times are GMT
Jump to:
Log in:         Remember me
Google
