The origin of the GRAVITATION.
Mikhail
re: The origin of the GRAVITATION.
Post by Mikhail »
Большое спасибо Михаил. Всего хорошего в новом 2015 году!
Спасибо! Взаимно.
I guess there are countless solutions of free energy devices among people.
Yes.
http://vitanar.narod.ru/MSmer/MSmer.html
Mikhail
Post by Mikhail »
Fcdriver
Post by Fcdriver »
A electric powered pendulum, basically
Mikhail
Post by Mikhail »
Hello to all.
AB Hammer
Post by AB Hammer »
Hello Mikhail
Mikhail
Post by Mikhail »
Hello,
and if we will put our efforts together to invent a perpetuum mobile simple, fast, small, powerful and valid?
Mikhail
Post by Mikhail »
Happy New Year! !!
Mikhail
Post by Mikhail »
Mikhail
Re: The origin of the GRAVITATION.
Post by Mikhail »
Hello
I haven't been here in a long time.
Perpetual engines are here: https://worldwide.espacenet.com/searchR ... acenet.com
Please look at the links in the signature and сheck the calculations, and write your conclusions.
Mikhail
Post by Mikhail »
Sorry Mikhail.
I don't see anything that hasn't been tried before.
Others and I have investigated water pressure and hydrostatic forces. It seems from the two types of machines, water weight and buoyancy, that you probably understand the cause and similarities between both, as well as the similar forces that will cause both not to work. Adding the magnet actuator just means the rotation around the bottom and top is driving the magnet, creating back torque equal to the force required to push against the pressure.
There was a giant water piston device with pistons inside of pistons, making use of difference in hydrostatic pressures from Spiteri. When I examined it I couldn't convince Mr Spiteri it did not work. He said it already did work. Pretty sure it worked if you pumped water in and out of the surrounding tank, or the internal chambers, requiring more energy than it produced.
https://timesofmalta.com/articles/view/ ... fer.189350
Mikhail
Post by Mikhail »
Sorry, your reasoning is all wrong.
To begin with - there are three engines.
As for the magnets - the forces counteracting the rotation act in opposite directions on each side and compensate each other.
In the pisron motor - everything is easily calculated, the four arithmetic operations are enough to calculate the forces acting on the pistons on both sides.
The FR20020000723 engine I did not calculate, it must be tested on a prototype.
Yep, reasoning correct so far.
Except for the transition, which is where the work is done.
In the piston engine moving water from one side to another, but you also have to lift the water the same amount it drops to drive the paternoster.
Buoyancy is just gravity powered, the forces are the same but backwards. The deeper into the water you go, the more pressure you have to work against. The water works against you just as much as it works for you.
A zero sum game.
Mikhail
Post by Mikhail »
"Except for the transition, which is where the work is done."
The useful work is done when the floats go down and up. In my opinion the magnet motor is just fine for making a toy for an office table.
"In the piston engine moving water from one side to another, but you also have to lift the water the same amount it drops to drive the paternoster."
In the piston engine the water does not circulate, the floats are under water and inside the floats no water. Inside there is the mechanism and the air. The text should be read carefully. For me is difficult to explain because I do not understand English, I use Google translator.
" The deeper into the water you go, the more pressure you have to work against. The water works against you just as much as it works for you."
Yes, reasoning correct. Read with the translator and try to understand. https://www.casimages.com/f/yeKdt5KBdUb
Mikhail
Post by Mikhail »
Hello,
Does anyone understand how it works and check the arithmetic calculations of my perpetuum mobile ??
