Only for those who don't know everything about gravity !!! :)
Releasing a spring supporting a mass.
spinner361 wrote: Thu Jul 21, 2022 7:43 am So the bottom is being pulled up at the speed of gravity because the top is releasing it's pressure at the speed of gravity? I mean, it's a pretty week spring, but it has a buildup of force, initially matching the force of gravity? It looks pretty cool.
It is cool to see something new. I had no idea this is how a spring/mass falls until the slow motion video was posted here in this forum.
The other cool YouTube video was the lifting of a mass when the string is cut between two supporting elastic bands.
So many things are hidden in plain sight.
Re: Only for those who don't know everything about gravity !!! :)
knobby1 wrote: Wed Dec 01, 2021 2:06 am I wouldn't say "free energy". Where did the energy required to get the elevator to a vertical 1m/s speed come from.?? And the energy required to lift the weight and spring to attach it to the top of the elevator..where did that come from..??
Smithy.
I reviewed Leafy's post. There is not difference in the example either moving at a constant speed or not moving at all.
Then Leafy did not state the lift is moving in gravity or it is in space?
If it is in space then it's floating and the spring is at it's default length.
So cutting the spring free. Well nothing happens.
If it is in a gravity field than the spring is stretched due to that and not because of the constant speed.
So the spring gets cut and we have seen what happens next. For there is not anti-gravity effect.
Leafy should have figured this out by now.
thx4
Post by thx4 »
https://youtu.be/K4r9UqskjiY
https://youtu.be/c_xuiCuf7cc
Toute ressemblance avec des personnes ou des situations ayant existé ne saurait être que fortuite même avec du carton. lol
Any resemblance with persons or situations having existed could only be fortuitous even with cardboard...lol
A++
Hi thx4
You did not hear this from me ;)
As the mass goes down it is in effect on the outer position.
As it arrives at the bottom it's anchor point is at the inner position.
However if the pendulum were allowed to pivot forwards and up then things get interesting.
So imaging a pendulum pointing at you at the top; That is the inner position.
As the wheel rotates the pendulum also rotates from pointing at you to pointing more to the right.
Let us use a ramp too assist.
The mass of the pendulum is following a horizontal path until it reaches the outer position.
Then it drops to increase rotation speed.
When the pendulum mass is at the height of the inner position a ramp is used to rotate it back to point towards you again.
It stays like that until it reaches the top position.
P.S. there are no levers in MT44 & MT45. But there is in MT30 !
Robinhood46
Post by Robinhood46 »
THX4,
Do you think he has a working time machine, and he stole Jon's top secret idea?
thx4
Post by thx4 »
agor95 wrote: Thu Aug 11, 2022 1:24 pm Hi thx4
This is the most interesting moment of the moment we are working on it, the suggestion is retained, but I doubt that this is the right way :)
If you can or have some time, you should take a look at the "caliber" of the watches that are wound at the slightest movement.
https://fr.wikipedia.org/wiki/Remontage ... 0%20rotor.
agor95 wrote: Thu Aug 11, 2022 1:24 pm P.S. there are no levers or belts in MT44 & MT45. But there are in other drawing.
In MT44/45 the levers are useless, we have a powerful torque, we even need something to hold the pressure, a system that is probably hidden behind the B gear.
A++
thx4
Post by thx4 »
Robinhood46 wrote: Thu Aug 11, 2022 1:34 pm THX4,
We should ask our friend @preoccupied, lol
A++
I don't think that the time machine needs infinite leverage, although I don't remember. I think it manipulates g-forces. I think that the secret that I discovered is that G-forces cause time dilation. So you can also move something past the speed of light without G-forces by removing the g-forces and that you can do with infinite leverage. So you can make a space ship that won't time dilate if moving quickly or you can make a projectile that can destroy a planet with infinite leverage because you can remove the g-forces and cause it not to time dilate. There is a device that amplifies g-forces very easily and causes time travel and its incredibly simple. You could go on a route with infinite leverage to make the G-forces but you would come into explosions when your gears go too quickly. When experimenting as a child I put a long gear train together and exploded my fastest gears with a small amount of input force. So my Stork's Bill design should work like that but instead of gear trains I use a stork's bill to create the acceleration that can extend the spring the necessary amount.
preoccupied wrote: Thu Aug 11, 2022 2:55 pm I don't think that the time machine needs infinite leverage, although I don't remember. I think it manipulates g-forces. I think that the secret that I discovered is that G-forces cause time dilation. So you can also move something past the speed of light without G-forces by removing the g-forces and that you can do with infinite leverage. So you can make a space ship that won't time dilate if moving quickly or you can make a projectile that can destroy a planet with infinite leverage because you can remove the g-forces and cause it not to time dilate. There is a device that amplifies g-forces very easily and causes time travel and its incredibly simple. You could go on a route with infinite leverage to make the G-forces but you would come into explosions when your gears go too quickly. When experimenting as a child I put a long gear train together and exploded my fastest gears with a small amount of input force. So my Stork's Bill design should work like that but instead of gear trains I use a stork's bill to create the acceleration that can extend the spring the necessary amount.
I think that what I remember while time traveling is existing as an energy moving forward in time but everything else was moving backwards. So you could record what was happening with a camera but you would record everything moving in reverse. Also you can create duplicates of items by taking them out of the subspace that you are traveling through and then bringing them into normal space. I don't understand duplications right now. Like duplicates have been created by me willing myself to want to time travel and then breaking my will to time travel when I see myself time traveling. I have a duplicate that was duplicated in Florida that I think became a fighter pilot down there that time traveled in front of me and then after I saw him I chose not to time travel and he existed as someone from a possible future. Time travel would be good for detectives because they would be able to directly witness happenings in the past without interacting with the past. Computers can reverse the reversed videos from the subspace and you could see it forward. I think that duplications manipulate possible futures or items found in subspace and switched to normal space. Like when Newton calculated pi he additional parts of pascals triangle. Maybe there is infinite space in all directions that don't exist (instead of parallel universes).
Capillary Attraction
Capillary action sound good till you realise you have to break the attraction at the other end. The only way I see doing this is through a repulsive capillary action like mercury and glass on one side of the tank. So you would attract on the left and repulse on the right which will rotate the wheel. The problem is both fluids would have to be the same density for to even buoyancy out? Or maybe the bottom ¼ mercury with top ¾ water and a glass wheel???
The capillary attraction is the same for any area of the disc surface.
So when the disc plates are apart nothing happens.
However when the disc plates a close the water stick to other water molecules as well as the disc surface.
This pulls down the disc on that side of the device.
While the disc plates are under water they can separate for there is no capillary action.
There is drag on the surface.
You should think about magnets pulling themselves up the narrow section.
However the water is pulling the close disc plates together.
So there is a possibility that generates a counter torque affect.
thx4
Post by thx4 »
https://youtu.be/I5GvwWKkBmg
the mastery of the moment!
thx4
Post by thx4 »
thx4
Post by thx4 »
To be consumed without moderation
https://youtu.be/MbucRPiL92Q
