Gregory
Post by Gregory »
Gregory .. to your previous - I hear yuh, and feel the pain - it can be exhausting research and more than tests the resilience, breaks help .. if energy can be made to just disappear ( usually to some background ) then it should be able to be made to appear ( also usually from some background ) - but it is essential to know where it went in order to start a reversal of the process - and that ain't easy to identify even tho you'd think it was, as we both know ..
I choose to walk a middle line and try to work within Newton's Laws of Motion and Classical Physics and Mechanics - and to do that the Energy Budget must balance, even if it is not obvious what and where that energy enters the system from .. at least I can, and have done, made a best estimate that it takes a little momentum from the earth moving towards the Wheel when it is pumped ( the usual missing half of the equations of equal and opposite reactions ) ..
To the causal observer in the same FOR it would just look like the the runner was always out of center of gravity .. and that is perfectly fine - however I have always said that to me having a scientifically testable semi-plausible explanation for the source of energy is just as, if not more, important than what the mechanics were to keep it out of the center of gravity - I'm in no rush to turf out Newton's Laws only for someone pondering it at a deeper level to connect some dots and keep him safe, which we should have been able to do ..
Hey, thanks Fletcher!
I investigated and also did some deeper thought experiments with these concepts and the connection with the background, aka Earth's frame.
I got some crazy thoughts, and get a few aha moments again. This can be also relevant to your theory. Now I understand much better why are you thinkered that much with Earth's FoR...
This would be a very long post I suspect, so instead I will come back with it some time later.
In many a sense Energy budgeting was what the sim-experiments were about wrt the horizontal swingers violating WEEP, and Noether symmetries, at the local level - where PE was gained ( Total Energy increased ) in a mechanical system ( Energy from the background ) which could then later be transformed into KE by releasing the PE into further movement - but the caveat was that the equal and opposite changers of acceleration given to the system had to come from momentum ( impulse ) sources thru a deep connection to that background ..
Good luck with the further experiments - it's not easy ( understatement ) to think up a mechanical method to isolate an up-change in Energy and reliably demonstrate it has a chance of being mechanically real in real-world ..
fwiw1 - this hypothesis which is the topic of this thread didn't recently pop into my head one day, or one week - it has been building block by slow block for 4 or 5 years now - think, test, and discard, start again - testing what I could with the sims but conscious that I probably could not sim the whole thing in one because it must " create " Energy at the local level - first I could not make the swingers lock-out reliably in a rotating environment - it blew up or crashed my sims and I could not proceed further in that investigative direction - you approached it in a more reliable way so it might no longer be the show-stopper it was for me until then - then you fixed the problems ( also a show-stopper ) I had with the A-Prime movements which would also crash or lockup the program .. and with your " fixes/workarounds " they are potentially not the same show-stoppers they once were - I have been able to push on further in these investigation directions which were road-blocked - altho I suspect I will not be able to bring all the sub parts and actions together in one completed sim ( that would be hoping for too much from experience ) - I hope I can repay the same favour for you one day, if not to just act as a sounding board in the directions you are exploring if needed ..
fwiw2 - some researchers choose to pay little or no heed to the story of Bessler, and find their own way to a runner - that's their prerogative - for me he left a compelling story and navigational mile-markers ..
A Hang-Together Principle ..
A Correct Handle-Construction ..
A Prime Mover ..
Something Special Behind the Stork's BIll ..
The dual opposed coordinated Pendulums in the Public Wheel Engravings ..
The 6 toys of the unpublished secret Toys Page .. n.b. not 1 or 2 toys and simple actions, but 6 .. there are 6 different toys and actions for a good reason - to me they suggest more a symbolism rather than absolute mechanical actions ( e.g. the SB pushing up a small arrow shaped weight ), and a story of partitioned or separate resources which when combined make a whole greater than the parts ..
Gregory
Post by Gregory »
Thanks Fletcher!
Right, so let's have a good dive into my thought experiments about inertial brakes and inertial engines (never mind those doesn't exist yet).
Let's state that an inertial brake uses no friction of any kind, not at all, so it is basically a frictionless brake.
I suspected that the inertial brake will inflict a torque on its stand/support/background while braking. It wasn't much important for me so far, so I haven't tested that in detail. But lately I made a test out of curiosity, and yes... As expected it really puts a torque on the background into the direction of the brake's rotation, just like any usual brake would do. This way if the background can be rotated around, then it will be spin up until the speed of the brake is matched, and at that point the action will be dampened down.
This is fine so far. Kinetic energy is pumped into the background, and if we measured, most likely we should find that the total energy is conserved.
Now, continuing this thought experiment I imagined that an inertial engine would supposedly do the opposite action, so it should cause the background to be pushed away into the opposite direction, meaning it would put a counter torque on the stand/support instead of dragging it along. This is still consistent with our everyday understanding, like for example an electric motor would also cause this counter-torque effect.
So, the inertial engine would try to propel itself faster and faster, but is there a limiting factor here? Like in case the background is counter-spin up too much, then it can't accelerate itself higher anymore? Basically it couldn't push against the background anymore, and I think that might be also correct. Such would also happen with a normal motor, if the motor's support/frame would counter-accelerate, then in response the motor's axle would start to be less and less accelerated/efficient too.
It's not obvious where the energy would come in the case of an inertial engine, and that's potentially a red flag. But otherwise, this is all still fine.
And now comes the crazy part...
Let's say I put a 100 Kg platform (for example a heavy, thick steel sheet) into the vacuum of outer space. Then I install two identical inertial brakes onto the platform. However I install, orient, and/or connect them in such a way that all of their workings and actions are mirrored on the platform. Meaning that whatever effect or action they may cause onto or against the platform, all of those forces, torques, etc will be cancelled for the platform...
Now, imagine we start the brakes with the same initial KE, and they start to brake. The individual torques they cause on the platform will be equal in strength, but opposite in direction, so every effect will be cancelled, and the platform would stand still and motionless while the brakes will be braking towards zero RPM.
(This is similar to pushing two sides of a seesaw upwards with the same force, in that case there is no movement at all, but there can be material stress too.)
Ok, but where the energy goes now?
The platform stands still, and not rotated or accelerated. Either we assume that the energy disappeared… Or we theorize that the energy is dissipated into the material of the platform itself, in the form of material stress, molecular effects, or heat maybe?
But is that true, where the energy goes really?
And if it turned into molecular stress/heat, then an intricate heat sensor could supposedly measure that.
Now, if we consider two hypothetical inertial engines arranged in a similar mirrored fashion… Those could theoretically accelerate without limit, because the platform can't spin up to limit their motion, every effect for the platform will be cancelled. So, in that case where the energy comes from? The machines would channel/siphon out molecular stress or heat from the material of the platform itself? Perhaps that's the remaining option, otherwise we would have to accept that energy comes and goes ex nihilo… or there is something else unidentified at play.
But isn't this KE (without any frictional or other dissipative forces) turning into or arising from internal molecular stress/heat sounds very weird?
So, an inertial engine (if exist) would siphon out material stress/heat from the ground or Earth, especially when used in these mirrored pairs? Sounds very much sci-fi stuff to say the least! Let me tell, I am not convinced any one way or the other, I just pondered through all of this.
And now Fletcher... What about your swinger experiment?
Let's assume the swinger experiment/swinger wheel works for real and do produce a gain...
Imagine you put one of that swinger cart or wheel at the north pole, and another one at the south pole, then you do the experiment perfectly mirrored, so that every effect for Earth cancels out.
Now, Earth can't move for you, not even an unimaginably tiny bit.
Then what happens with the swinger wheels in this case?
Do they stop working in these conditions, or what?
Or, if the swinger wheels would still work, then what is the explanation?
Where does the energy come from and how would it be transferred in this case?
That was my thought experiment so far. Hope you like it! ;)
So, what do you think about all of these deep dive mindscapes?
Hey Gregory .. very interesting thought experiments - I do have some immediate thoughts and comments about them ( still refining, more coffee ) but will hold off relying in any detail for a couple of days if that's ok, or only take a quick shallow dive into the rabbit hole lol ..
Long weekend here ( ANZAC day ) and am feeling the effects from digging wet sticky clay yesterday - concentration is at a premium atm ..
But I will start with this ..
Newton's Laws of Motion, from memory and paraphrased by me ..
1. ( Newton's Inertia Law ) A Body at rest will remain at rest, and a Body in motion will remain in motion, unless acted upon by an unbalanced force vector i.e. a net force .. that force must be external to the Body Frame Of Reference ( FOR ) ..
2. Force equals Mass times Acceleration ( f = m * a ) - and the ratios of Mass to Acceleration gives the force vector magnitude by simple rearrangement of the equation ..
ETA iinm .. f = m * a is the basic tenet for deriving of the Law of Conservation Of Energy ( COE ) wrt the Laws of Thermodynamics ..
3. For every Action there is an Equal and Opposite Reaction - this is not FOR dependent and is across all F'sOR ..
Gregory
Post by Gregory »
Fletcher wrote: Thu Apr 24, 2025 10:12 pm Hey Gregory .. very interesting thought experiments - I do have some immediate thoughts and comments about them ( still refining, more coffee ) but will hold off relying in any detail for a couple of days if that's ok, or only take a quick shallow dive into the rabbit hole lol ..
Right, take your time.
Never rush carelessly into the rabbit hole, it might be dangerous. :D
Respect for the warriors!
You might have a use for some good gunfire breakfast for that amount of clay digging!
A potter/ceramist friend or neighbour would also come handy...
Sure, Newton would defeat me in any math task ever single time, I have zero chance... The guy was a true calibre, a legend really!
I just hope I didn't make some stupid mistake in my thinking... Newton would dismiss me in no time.
Right, our platform or Earth is just doing its everyday motion through space. Then, with my thought experiment I periodically apply equal (in magnitude) but opposite (in direction) forces to it. So, according to Newton's laws it should continue its motion unaffected, because the forces cancel, so there is no net force acting on the body. However, the reaction will effect the bodies doing the pushing from opposite directions, I was thinking along those lines...
About heat transfer via internal stress in materials...
There are moons of Jupiter and/or Saturn which heated up by the gravitational effects causing stretch/stress forces inside the body of such moon. This info is just popped into my mind at random. That's interesting, maybe my thinkering is not fully wasted then.
Gregory
Post by Gregory »
(Or maybe still it is)
On the other hand, I have a strong gut feeling telling me that I am really not convinced about this...
Consider the following extra thought experiment:
Let's assume we have a big heavy flywheel, like hundreds or thousands of Kg heavy. In a carefully designed experiment we accelerate it up to let's say 500 Rpm, like with an automated motor controlled with electronics, etc. So, there is plenty of KE and AM stored in that rotating monster... And once the flywheel is up and rotating at 500 Rpm, then we electronically actuate and apply a braking system.
First... We apply an automotive brake and we see the brake disc getting hot and glowing up as it quickly tries to dissipate/convert that amount of KE. It starts to glow at somewhere around 700 degrees Celsius. Let's say the poor brake stops that monster flywheel within 5 seconds, and we measure the brake disc's temperature to be quite high.
Second... We apply a powerful theoretical inertial braking system in a paired/mirrored fashion mentioned earlier. Note that in this paired manner the brakes can't cause a net torque on the background/frame. Sure, the brakes might put a lot of opposing torque/stress on whatever support structure/frame they attached to, but let's say the support is designed strong enough and holds easily. Assume this braking system also can stop the monster flywheel within the same 5 seconds, and we also measure the temperatures. Now, as there is no friction involved here I strongly doubt that any material component or the support frame can heat up that much. So, most likely we will find that the components didn't heat up much.
After the two experiment, we compare the temperatures and evaluate the respective energy balances, and probably find that we don't know where energy disappeared in the case of the inertial brake, because we didn't measure the amount of heat/sound/whatever required for that. Then what now?
Like I can ask two muscle colossus strongmen to push against a thick hardened rod with full force for some time, and measure any heat building up in the material. Perhaps with the right equipment I can measure some change, but most likely not dozens or hundreds of degrees.
So, I am not sure about this. I have a feeling that perhaps something is not quite right, or maybe something unknown is hiding around here. Guess I will only find the true answer if I do the experiments for real, I got as far as possible without that. It's not necessary useful to enter the land of pet theories (sure, I got one) before doing the job for real...
Otherwise Fletcher, sorry if I hijacked your thread with all this craziness, it's probably gone too far. We can go back to topic (or back to normal). I just wanted to shake up the cocktail a little bit, and see if it tastes better or worse that way... or whether we can find some new ingredient to it. 8)
Writing in Progress ..
Thanks Fletcher!
Right, so let's have a good dive into my thought experiments about inertial brakes and inertial engines (never mind those doesn't exist yet). Right - afaik they don't exist at all, and perhaps never will !
Let's state that an inertial brake uses no friction of any kind, not at all, so it is basically a frictionless brake. What is friction ? ( it is Work Done as it dissipates energy ) If it is a brake then it is applying a force, and a force over a displacement is Work Done - if it is not a friction brake then the force can be something else like a Lenz Law effect ..
I suspected that the inertial brake will inflict a torque on its stand/support/background while braking. It wasn't much important for me so far, so I haven't tested that in detail. But lately I made a test out of curiosity, and yes... As expected it really puts a torque on the background into the direction of the brake's rotation, just like any usual brake would do. This way if the background can be rotated around, then it will be spin up until the speed of the brake is matched, and at that point the action will be dampened down. This is fine so far. Kinetic energy is pumped into the background, and if we measured, most likely we should find that the total energy is conserved.
If you accept Newton's 3rd then for every action there is an equal and opposite reaction .. so when something is driven to increase its rpm then whatever constitutes internal frictions in the thought experiment will create a counter torque in its stand etc - just like an electric engine you mention later, and the example I have personal experience with - that being, and aeroplane propeller - when prop rpm is increased it causes a counter-torque on the plane which has to be compensated for with aileron input ( big turboprops ) - so in the sense of a wider picture Energy is totally conserved ..
Now, continuing this thought experiment I imagined that an inertial engine would supposedly do the opposite action, so it should cause the background to be pushed away into the opposite direction, meaning it would put a counter torque on the stand/support instead of dragging it along. This is still consistent with our everyday understanding, like for example an electric motor would also cause this counter-torque effect. Yes , if one physically existed it would not be reactionless ..
So, the inertial engine would try to propel itself faster and faster, but is there a limiting factor here? Like in case the background is counter-spin up too much, then it can't accelerate itself higher anymore? Basically it couldn't push against the background anymore, and I think that might be also correct. Such would also happen with a normal motor, if the motor's support/frame would counter-accelerate, then in response the motor's axle would start to be less and less accelerated/efficient too. It's not obvious where the energy would come in the case of an inertial engine, and that's potentially a red flag. But otherwise, this is all still fine.
Personally I do believe that Newton's 3 Laws are always present, and always act across all Frames Of Reference - so I am unable to divorce myself from this constraint to imagine a pure inertial engine ( as has sometimes been speculated on ) - that, and the Laws of Thermodynamics which basically say that Energy is Conserved, heat flows from hot to cold sinks, and entropy increases over time ..
Let's say I put a 100 Kg platform (for example a heavy, thick steel sheet) into the vacuum of outer space. Then I install two identical inertial brakes onto the platform. However I install, orient, and/or connect them in such a way that all of their workings and actions are mirrored on the platform. Meaning that whatever effect or action they may cause onto or against the platform, all of those forces, torques, etc will be cancelled for the platform... OK ..
Now, imagine we start the brakes with the same initial KE, and they start to brake. The individual torques they cause on the platform will be equal in strength, but opposite in direction, so every effect will be cancelled, and the platform would stand still and motionless while the brakes will be braking towards zero RPM. OK ..
(This is similar to pushing two sides of a seesaw upwards with the same force, in that case there is no movement at all, but there can be material stress too.) Got it , good example ..
My problem is I can't imagine a reactionless ( doesn't use friction braking ) inertial engine/braking system - but if I imagine 2 opposite braking systems exactly cancelling out then the background will not have a net torque on it - and all the KE will theoretically be transformed into stress, deformation ( quantum levels ) and lost to the system as heat. sound, vibration etc .. that's the currently accepted dogma which falls within the framework of the Laws of Thermodynamics ..
The scientific principle basically says that experiments explore and produce results - but to be meaningful ( beyond thought experiments ) there must be a control experiment ( the usual ) to compare against with our comparison experiment - then we collect data and look for a statistical variance - if one is found that is statistically significant then that data can be used and analyzed to either validate, or falsify the hypothesis .. in this case pure inertial engines/brakes ( afaik ) do not exist to compare against a traditional engine/brake system .. there have been various attempts at inertial engines which change shape and are motor driven - these create Centripetal Forces - but no one has been able to harness these Cp's ( centrifical, centrifugal ) to generate extra motion ( KE ) above Energy given to the system ..
Imagine you put one of that swinger cart or wheel at the north pole, and another one at the south pole, then you do the experiment perfectly mirrored, so that every effect for Earth cancels out. OK .. but of course the earth is not density and gravity homogeneous, nor perfectly round etc - so statistically that is not possible, or at least very difficult to arrange - but lets imagine we could make them perfectly opposite in every way for the thought experiment ..
Now, Earth can't move for you, not even an unimaginably tiny bit. Then what happens with the swinger wheels in this case?
Do they stop working in these conditions, or what? Yes, they stop working ! .. because every action has an exact equal and opposite reaction .. and the theory relies on the swingers being accelerated into a position of torque by the whole wheel being bounced up and down - inside the hypothesis the rebound coming from the earth moving upwards to meet it ( this is an attempt to balance the energy budget that COE demands ) to not violate Newton's Laws, and the Laws of Thermodynamics, and not disrupt Noether's Theorem of Symmetries .. if the whole-Of-Wheel ( e.g. 2 opposite wheels example ) cannot be bounced because they cancel/null then the swingers can not be set to and excess of torque to cause a rapid acceleration to overcome local energy losses ..
Or, if the swinger wheels would still work, then what is the explanation? Under the exact conditions of the thought experiment imo they can't work - for every action there must be an equal and opposite reaction, and for a wheel to increase its net angular momentum that momentum must be drawn from a momentum sink, in the hypothesis ..
So, what do you think about all of these deep dive mindscapes ? They might give me headaches lol .. the bottom line imo is without a real "pure" inertial engine/brake to test against a control experiment and gather real data then I run into a mind acceptance problem - fwiw, my hypothesis is NOT a " pure " inertial engine ( it is a PART inertial engine in that internally the A-Prime morphs shape and back to reset ) .. .. Everything with mass has inertia - according to accepted Laws it needs an energy source ( harnessing pseudo momentum input ) - what it does is use the A-Primes inertia whilst morphing to force the A-Prime to complete is shape transition ( the follow-thru ) - and this morphing episode causes a down force ( pump ) on the platform/support it is attached to - which then is rebounded back up ( wrt tensional, deformation, structural, planetary movement forces ) which accelerates and lifts up the one-way swingers into a position of torque abundance to cause the wheel rpm to steadily increase via a positive feedback synergy - if I were to sim it then I could only use springs as rude substitutes for the earth rebound pump and COE would probably be totally observed in the sim ..
Time for coffee ..
Gregory wrote:
fletcher wrote:But I will start with this ..
Right, our platform or Earth is just doing its everyday motion through space. Then, with my thought experiment I periodically apply equal (in magnitude) but opposite (in direction) forces to it. So, according to Newton's laws it should continue its motion unaffected, because the forces cancel, so there is no net force acting on the body. However, the reaction will effect the bodies doing the pushing from opposite directions, I was thinking along those lines... As I said earlier to balance the energy books ( COE wrt Newton's Laws and Thermodynamics ), and keep Newton safe, then for an overunity gravity wheel to rapidly accelerate and gain in momentum ( and do external " Work " ) it must be given some momentum as an Energy input substitution - and all I can think of that is ambient, and in the wider FOR, is the earth giving up some of its momentum to the wheel on its journey as it wobbles and rotates around the sun ..
There are moons of Jupiter and/or Saturn which heated up by the gravitational effects causing stretch/stress forces inside the body of such moon. This info is just popped into my mind at random. That's interesting, maybe my thinkering is not fully wasted then. Even the moon and the earth interaction experience gravitational tidal forces which cause the mantle to the core to move - altho the moon is no longer volcanically active there will be some small seismic activity but not from tectonic plate subduction etc .. ateotd everything is in a state of flux ( heating and cooling, stresses and strains ) as it heads to entropy and that presents a potential for movement to possibly be harnessed in some shape or form ..
First... We apply an automotive ( friction ) brake and we see the brake disc getting hot and glowing up as it quickly tries to dissipate/convert that amount of KE. It starts to glow at somewhere around 700 degrees Celsius. Let's say the poor brake stops that monster flywheel within 5 seconds, and we measure the brake disc's temperature to be quite high. OK ..
If only we had a very real " pure " inertial brake that didn't use friction ( or equivalent stopping force ) to test against traditional classical mechanics eh .. if you come up with one we can revisit ..
Otherwise Fletcher, sorry if I hijacked your thread with all this craziness, it's probably gone too far. We can go back to topic (or back to normal). I just wanted to shake up the cocktail a little bit, and see if it tastes better or worse that way... or whether we can find some new ingredient to it. 8) my martini cocktail tastes good - shaken, not stirred ;7) .. not all rabbit-holes lead Alice to Wonderland - sometimes logic bubbles to the top - cream might rise to the top but crap sinks to the bottom lol - that's the risk we all take in every thought experiment and discussion - the point is to challenge what we think we know and maybe gain some deeper understanding ..
