Friendly Little Note
Ed
re: Friendly Little Note
Post by Ed »
jim_leip wrote:Unfortunately many think that the 1 lb raising 4 pounds was somehow a hint as to how Bessler's wheel worked. It was not a hint. It was sarcasm and ridicule directed toward Wagner.
Stewart wrote:Und wenn ein Pfund ein Viertel fällt/
Es vier Pfund hoch vier Viertel schnellt. &c.
and when one pound falls a quarter,
it shoots four pounds up four quarters. &c.
Is it customary to point out ones sarcasm and ridicule?
jim_leip wrote:The answer is/was not gravity. The answer does not involve gravity weight. But it does involve inertial weight and momentum weight. I believe Bessler's mechanism manipulates inertia (the resistance to starting of motion) and momentum (the resistance to stopping of motion) in such a way that that it pumps the weights in and out and this in and out produces perpetual forceful rotation.
jim_leip wrote:Oh, boy. How do I answer this without getting into details? Without details, it seems contrary to how things work. I'll quote Bessler...
The frequency and urgency of your posts on this suggests you want to have a discussion. The fact that you won't discuss details suggests you've had a rock resting on your head too long. :-)
jim_mich wrote:Those things you say are screws are obviously coil springs around the rod that passes through them.
Then, a short time later...
jim_mich wrote:Yes, linear bellows looks more likely, which would make the rest of the system also bellows
Look, we all see things a bit differently. If we could substitute impatience with a bit of empathy, we just might get somewhere.
Dwylbtzle
Post by Dwylbtzle »
gitterdid:
i looked at yer picture
even though i saw a baby blue swastika in the upper right hand corner
and that kinda scared me
but i cowboyed up
and i looked at it all
and i think yer lever will work once and then have to be re-set
nice welding though
drawing that bead ain't easy, i know
Interestingly, cloud camper used the word 'pablum' in his above post. This word is so rare on the forum that it has only previously been used by one other member: This member was Techstuf (Mich Robinson) who was banned long ago.
The global loon pool must be tiny :D
Dwylbtzle
Post by Dwylbtzle »
i camped in a cloud forest once
and there were no wheels
so peaceful
Ed
Post by Ed »
Lol. He did it to you too!
Dwylbtzle
Re: re: Friendly Little Note
Post by Dwylbtzle »
compared to which globe?
i'm sure we heve a higher percentage per unit of denizens than most planets
so
in sumsory
did fletcher mathematically nix the momentumulum motor completely?
did i read that right?
..(or merely momentously, even?)
No Dwy ..
I was merely pointing out that for linear situations a force gives a mass momentum & KE.
N.B. a force is simply something that pulls or pushes something.
We often talk about objects in motion as having force - what they in fact do is transfer some of their momentum & KE, a lesser amount than they originally received i.e. f x d = joules, between objects.
So there is no additional force or energy available above the sum of the parts - to do so would require that I =/= m.
And this is the situation that jim_mich & pequaide believe happens in a rotational environment, but for different reasons I suspect - without raking old coals peq. believes that I=/=mr^2 & is closer to I = mr - jim_mich has a different reason for finding an available force to accelerate a rotational system that I think is different from peq's.
I am in the process of rereading parts of this web site & Bill's - read them this morning & will go over again tonight, before I answer to jim_mich's reply earlier - it's been refreshing to visit all this stuff again after many years, i.e eyewitness accounts, examinations, writings & the wiki - I looked at them with only two thoughts in mind - that Bessler was as honest as he could be & that he obviously had to leave something out.
Dwylbtzle
Post by Dwylbtzle »
oh--ok
cool
i thought when i read that part about nothing being left over to do work
--you were saying that meant it wouldn't work with jim's idea at least
so the dream is still alive
hehe
cool
i wanted it to be possible because it wouldn't NEEEED gravity
that just flat kinda tickles my perverse funny bone
if you get me
after all this and it turns out to be that
ok, yeah
if i had a gun to my head and had to choose
i'd say bessler wasn't lying
but i wouldn't shoot myself in the head if i DID find out he was hoaxing
if real i think he left the quantum cheat out
and that's the crux of the biscuit
though i want the momentumulum to work
i have a hard time with anything that just goes because it went
despite that thing in my avatar
lol
if i saw that i'd shoot it
http://upload.wikimedia.org/wikipedia/c ... _2004).gif
ETD: And of course we apply a negative to prove the positive in linear exchanges - we say that it takes -f1 x d2 or -f2 x d1 [KE] to stop a moving object, to prove that its a zero sum game.
Dwylbtzle
Post by Dwylbtzle »
that's what i have trouble with:
you have a car with a bitchen momentumulum motor purring in it
no gas no gravitas--just CF driven momentum
and you let out the clutch
doesn't the momentum in the motor get absorbed/neutralized as soon as you try to do "heavy work"?
that IS a collision of force imperatives
and if that's a zero sum game then you don't exactly have a lamborghini goin on in cell block number nine
a flywheel made of pure neutron star substance would be dense enough i guess
if you geared it all up real efficiently
lol
getterdone
Post by getterdone »
Yes Dwee, you guessed it, the global loony pool is tiny, but I still manage to dip a toe in there every now and then.
Now, back to my twisted idea's concerning CF, in that particular design, the reset is to small for me to mesure .
As the lever comes around to the 5 o'clock position, the track only has to lift it about .5 of a cm, so that it's not touching the perimeter.
That's just the start of it.
If I'm understanding what Jim is saying about CF correctly, then what I'm doing is artificial CF. In the real world ,the faster the wheel spins , the more pressure the weights put on the perimeter. In Leo Land, one vertical lever at the 12 o'clock position, squeezes another lever at the three o'clock position, and puts more pressure on the perimeter
Mine works in slo-mo
Weird eh
jim_mich wrote:
...snip... He said (I'm paraphrasing it) that the weights were the "perpetual motion". I'd need to look up Bessler's exact words. Here they are...
Bessler wrote:NO, these weights are themselves the PM device, the "essential constituent parts" which must of necessity continue to exercise their motive force (derived from the PM principle) indefinitely - so long as they keep away from the centre of gravity.
This seems to indicate only weights, and no secondary mechanisms.
Well, I've read thru the available material again this evening I mentioned earlier.
First let me state that I agree that Bessler did not call his wheels gravity wheels - that descriptive is never attributed to him - what also seems clear to me is that in the quote above he is clearly describing a simple, dare I say, common place, out-of-balance system - MT is full of them in different guises & it is there that he makes reference to the "Prime Mover" in that nothing can be achieved without it N.B. I am paraphrasing also for expediency as everyone can read full quotes or documents for themselves.
jim_mich wrote:
Note that in the many translation certain phrases get mixed and matched - "preponderance" - "centre of gravity" - "out of balance" - "over balance" - they all convey the thought of more force in one direction than in the reciprocal direction.
I've asked myself, what phrase would Bessler use to describe more forward rotational motive force than rearward rotational motive force? The only logical way to rotate a wheel requires more force in one direction than in the reverse direction. It requires unbalanced force, over balanced force, a preponderance of force. And I keep coming to the conclusion that he would have said over balance or out-of-balance or a preponderance. And thus the same words take a different meaning depending upon whether the weights are moved by gravity of by their own inertial momentum force. In other words the weights gain force from their moving.
Yes, they gain force from their own moving because they cannot find a position of equilibrium as long as they remain in motion - this sounds just like a typical OOB system if we forgot for a moment about how the weights are lifted or repositioned as Bill has been saying for years.
Bessler also used & described the term "excess impetus" & the eyewitness accounts in particular draw attention to this by the noises heard - I'll come back to that.
jim_mich wrote:
Initially Bessler attempted to say that his wheel was not turned by weights. Wagner called him out on this, saying that obviously his wheel contained weights.
Could you provide a reference for this, where he said his wheels were not turned by weights ? - I know he was clear that they didn't need restorative means such as chains & hanging weights, winding [e.g. torsion] or springs like clock work mechanisms - the motive force was internally derived but wasn't stored energy it seems, which indicates an on demand system from an impressed start up force given to the wheel - his early wheels certainly seem to be OOB systems where a cord was untied to let rotation begin.
jim_mich wrote:
But how could Bessler keep his secret and at the same time explain that it was the motions of the weights that rotated his wheel? Go back and read Bessler's words with a different perspective in mind. Then you will see what I'm saying. Bessler said absolutely as much as he could say concerning the matter, without out-right blabbing the exact details of how his wheel worked.
You may be right, however I could also interpret it to have a double meaning - the OOB system turned the wheel but it was not responsible for the restoration of PE each cycle - the Prime Mover achieved this & was the real reason behind the wheels success - so if it were a CF force generated by moving weights that then drove an OOB system to sustain rotation then I probably wouldn't call it a gravity wheel either because without the special device to lift & reset weights the wheel could not sustain rotation N.B. there is no doubt in my mind that a gravity only solution can not work - Wagner was an opportune target to be taunted but also to get the message across that OOB systems only can never work.
OK, back to the weights & the eye witness accounts.
I think Christian Wolff's two accounts of the same viewing are interesting - the first in 1715 mentions several weights allowed to be handled covered in a handkerchief - he says they are cylindrical - he talks about weights being heard hitting the rim of the wheel - he says he saw thru a gap short boards at right angles to the rim - he says that when the weights were replaced a spring sound was heard [extending upwards] - this might indicate there was a slip by Bessler as a spring was compressed as a weight was positioned - if so, a weight spring loaded would fire like a jack to lift a weight quickly upwards at or near 6 o'cl [this is one of two possible positions, 6 & 12 o'cl, where OOB designs need weight lifting to reset].
Wolff makes the big deductive leap that the same weight he handled is the same one he heard impacting the rim & short boards at the periphery - this may not be so & be Bessler misdirection.
In Wolff's letter to Schaumaker in 1722 he adds further & different material - he now says a single weight was observed & handled - that it was covered by the handkerchief & that it was cylindrical & not very thick of about 4 lbs [e.g. like a coke can] - he says they were only able to handle the length of the cylinder to judge its weight & not touch its ends - one could speculate that the ends contained some information that Bessler did not want to share - once again he deduces that the single weight that is handled is the same weights heard in impact on the down doing side when the wheel is in motion.
Anyway, clearly this is a multiple weight system located near the rim periphery & impacting compartment boards of some sort - Wolff speculates that there is some internal force that causes the lifting of weights from the bottom &/or causes the ever faster falling/swinging of the rim weights to cause the fast & impressive acceleration he witnessed.
Ockhams Razor, if it looks like a duck & quacks like a duck it probably is a secondary OOB system near the rim.
The best falsehood is one sticking closest to the truth.
I'm not saying your interpretation is wrong, just that IMO there is room for more than the one interpretation - it's a natural step to combine two systems into one if it can be done but perhaps it couldn't be, for good reasons ?
It's getting late for me, yawn.
pequaide
Post by pequaide »
It was suggested that a closed system can not have a change in momentum.
A closed system will have no change in momentum if there is no application of outside force.
If there is an application of outside force then the system must have a change in momentum; in accordance with Newtons Laws of Motion.
Ballistic pendulums prove that kinetic energy is not conserved in a closed system; so we can drop the idea of KE conservation in a closed system.
If a ten kilogram mass is dropped for .050968 meters it has a velocity of 1 m/sec and it will have dropped for .101936 seconds with and applied force of (10 *9.81) 98.1 newtons. The ten kilograms will have 10 units of momentum. And the Force * time is 10
A one kilogram mass with a momentum of ten units will rise to 5.0968 meters. If dropped it will fall for 1.01936 seconds with an applied force of 9.81 newtons. And the Force * time is 10
But; If you attach the one kilogram to 9 balanced kilograms for an acceleration of .981 m/sec/sec instead of 9.81 m/sec/sec then the time over with the same force acts is lengthened to 3.2235 seconds for an F * t of 31.622. The final velocity of the ten kilogram total will be 3.16 m/sec and the momentum will be 31.622 units of momentum.
The nine balanced kilograms could be a 9 kg rim and the one kilogram could be that inside mysterious mass.
Increase the time over which the same force acts and momentum will not be conserved.
Throw it up and ride it down.
getterdone
Hi Pequaide
Just a thought
The closed system, in our case, the wheel, Sits on a stand. It holds the weight of the entire structure. It seems to me( I could be wrong )
that we should be looking for ways to put some the weight from the backside on the axle
I think that it's the only way out of the box
cloudcamper wrote:JM is back to his same tired and unsubstantiated assertions that CF is non-linear and therefore must be nonconservative.
But this can easily be proved false by noting the direction any object on the rim of a high rpm wheel departs when CP loses it's hold on that object.
If JM's theories were correct, the object would fly away radially from the center at high speed. But unfortunately for Jim, this never happens.
Loose objects departing a high rpm wheel always depart tangentially, 90 degrees to the developed CF vector. This shows that even tremendous values of CF developed at high rpm instantly and completely vanish the moment that CP loses it's hold on the object.
In the post Fletcher made in C of AM thread here
http://www.besslerwheel.com/forum/viewt ... &start=255
he simulated the release of two masses in a rotating environment, and the opposite, the pull back in toward the axis of rotation. The radial and spiral movements are frame dependent. One observer sees radial movement and another observer see spiral movement. The lesson here is in both frames all of the forces can be accounted for, and my point is, again, whichever frame you choose to support your wheel and axle theory, the one with CF, coriolis or euler forces or the one without CF, coriolis, or euler forces, the wheel and any mass inside, either loose or tethered, is the tail of the dog, and the axle is the dog.
Unless the loose or tethered mass of your wheel has its own supply of energy other than its own gravitational potential (like the often cited ice skater example does), a wheel can't torque its own axle. If it could, we could all lift ourselves by our bootstraps out of quicksand.
Just my friendly little opinion.
