Just thought I'd pass it along.
From http://home.netcom.com/~sbyers11/grav11k.htm ...
Weight: When lifting an object you are not feeling an unknown force field between the earth and the object. The earth has interacted with the space by shielding and the space is singularly responsible for the force you feel. It is important to view the process this way to begin to realize the power density in every cubic inch of space. Once we are able to focus this flow, it will not only be possible to counteract gravity on an object, but it will also be possible to magnify the effect. The force you feel when lifting is caused by the unbalanced flow of radiant space. The only attribute within the object is the ability to shadow the unbalanced flow. The weight (force) is not in the object.
