Hi Alex
Indeed your game is interesting to say the lest, but I want to play it a deferent way, let us do away with the incline plain and attach springs to the orbiting masses that can slide on arms/spokes from its center and out to the periphery, lets now rock the wheel in a oscillatory fashion, like the vibration of a plucked string, this game could stimulate me for hours.
Ken
Play vortices...
re: Play vortices...
All material motion requires a source of energy, a body to store the energy, and the energy of motion.
re: Play vortices... of the arm
Hi Ken!
An arm/spoke with a satellite mass that can slide and press/depress a spring attached at the end of the arm(or at the hub...is the same situation),can be an image of this vortex-anti vortex game on an inclined plane.One spoke,two or more...
All the Bests! / Alex
Hi Alex
Looks like there are two or more ways to play this game, all the more fun.
Ken
Ken
Hi Ken!
It's a new game,that's all!
Hi Ken!
You know the spiral trajectory of a vortex...
If you take a look at www.geocities.com/iacob_alex then click on "Some_Drafts"/text044.jpg you will find the title "Self pulsatory wheel".
Here,you can see two big arms,with satellite masses that can slide and press/depress a spring attached at the end of the arm,so to track a possible spiral trajectory(D=driver).
The two small equal arms( mass and spring),are intended as a temporary storage system(F=follower).
In the hub,we have the switching motion of the long arm-short arm requirement.
The abstraction is that a free moving mass-spring on the arm,can develop a stronger inertial reaction/vortex.
..it's a simple recommendation,to use "something alike".
A windmill/watermill gets its power from slowing down the wind/water flow.
As a "marker",we can perceive the vortices,outside the power collector.
In the "deeps" of a vortex,we can understand a specific shape-reaction of the inertial frame.
For a possible gravity power collector,in an irrotational field (without vortices)/gravity ,the only solution is to play inertial effects,directly.
So ,instead of an intermediate collector-fluid-inertia relation,we have a short collector-inertia connection.
To be concise,play vortices suggestion,can be comprehended as to play inertia,at once.
Hi Ken !
I will try to make a connection,between your suggestion ,at :
http://en.wikipedia.org/wiki/Moment_of_inertia
and a short movie about vortex ,at :
www.youtube.com/watch?v=XkAPv5s92z0
Any motion in our living space (Earth) is related with gravity and inertia.
Gravity,as a conservative vector field is irrotational (not rotating or involving rotation ),we can,t twist it.
Inertia is more more permissive...we can play vortices with moment of inertia (rotational inertia).
For a gravity motor,this vortex game,can be imagined as a slow fall down-rapid lift of a mass(...higher than the starting point...).
If we can proof this "paradox",we have a "key".
All the best! / Alex
.....with gravity fall and rotational inertia , having in mind the images of the incoming waves at the sea- shore .
The allusive , fascinating and "desirable" phenomenon , at :
http://en.wikipedia.org/wiki/File:Vorte ... oburst.gif
It seems that , the cosmic pattern of the "free and fresh"motion is vortex :so ,let's play it!
Al_ex
Al_ex
....with a simple device , as you can see at :
www.vortexhydroenergy.com/technology/
....extracting energy from a water flow ,due the pressure unbalance , rezultanta in an oscilatorul lift..."unlike any existing technology",
Al_ex
Al_ex
.....as you can see at : https://youtu.be/0jHsq36_NTU
.....but as a repetitive 360* ( spiral trajectory ) , only?!
I have in mind a "modified" trebuchet...
Al_ex
Al_ex
