| View previous topic :: View next topic |
| Author |
Message |
broli
Total Words: 47,503
Reputation: None
Total Words: 922,877
Reputation: Highly regarded
Posted: Sat Nov 08, 2008 9:50 am Post subject: re: energy producing experiments |
| Quote: | | Please explain the "what if" and how both rim and cart movement is initially accomplished and maintained. |
I agree with broli, you are not getting the gist of your concept across to us.
You have answered the 'what if' but instead of answering the rest of the question you post a materials list and instructions for building something that I for one fail to see of any value except wasting PVC pipe and time.
Please answer the question of how movement is initiated and then maintained to produce the % power increase you speak of.
If it had paddles you could twist it back and forth causing the spheres to hit the paddles, a 1950's toy I believe was called a "paddy-whacker".
Ralph |
pequaide
Total Words: 160,725
Reputation: Acknowledged
DrWhat
Total Words: 88,230
Posted: Sun Nov 09, 2008 11:18 am Post subject: re: energy producing experiments |
Pequaide I hope you don't mind me putting these images up. If you do let me know. I believe these are the 3 images you are referring to.
| Description: |
| Filesize: |
115.27 KB |
| Viewed: |
377 Time(s) |
| Description: |
| Filesize: |
74.62 KB |
| Viewed: |
369 Time(s) |
| Description: |
| Filesize: |
115.05 KB |
| Viewed: |
343 Time(s) |
_________________ I only realized too late that life was short. |
pequaide
pequaide
Jonathan
Total Words: 229,845
Reputation: Well respected
Posted: Sat Dec 13, 2008 7:15 am Post subject: re: energy producing experiments |
Only members of the group can see the files section. Luckily, I understand what you mean, and can assure you that it is not a source of free energy, because they would have noticed that when they use this method to slow the rotation of spacecraft.
The primary problem with your math is that it seems valid no matter what the radius of the 4kg cylinder is, and since this can't be true, the math must not actually be valid. For the sake of argument, suppose that the radius of the hollow cylinder is 1m. This means that the initial angular momentum is roughly
L=2mVr+MVr=2*1kg*1m/s*1m+4kg*1m/s*1m=6 kgmm/s.
Now suppose the strings are 1m long each, so that the spheres end up at a radius of 2m. Then the angular momentum will be
L=2mu(r+l)+Mvr,
where geometry requires
u=(r+l)v/r.
Simplifying, we have
L=2m(r+l)v(r+l)/r+Mvr
=2*1kg*(1m+1m)*v*(1m+1m)/1m+4kg*v*1m
=12v.
Since the net torque on the system is zero, the angular momentum must be conserved:
6=12v,
which means that v, the final tangential speed of the hollow cylinder, will be 1/2 m/s.
The initial energy of the system would be
E=(1/2)(2m+M)VV=(1/2)(2*1kg+4kg)*1m/s*1m/s=3 J.
And the final energy of the system will be
E=(1/2)(2muu+Mvv)
=(1/2)(2*1kg*1m/s*1m/s+4kg*1/2 m/s*1/2 m/s)
=3/2 J.
I can't guarantee that this is all correct because I'm sleepy, but the general conclusion is correct: the momentum exchange occurs in an inelastic manner, so the system ends with less energy than it started with.
_________________ Disclaimer: I reserve the right not to know what I'm talking about and not to mention this possibility in my posts. This disclaimer also applies to sentences I claim are quotes from anybody, including me.
pequaide
pequaide
pequaide
Posted: Thu Dec 18, 2008 3:28 am Post subject: re: energy producing experiments |
Thanks Scott; once I figured out how to post pictures it was easy. Great site.
In the picture above the wheel that is being used as a pulley has a mass of over 3,400g, but its mass distribution is unknown. Let’s assume that the effective rotational mass of the wheel is equal to a rim that has a mass of 2,300g. The red and blue cylinders on the ends of the strings that drape over the wheel are solid steel and have a mass of 4,210g each. The wheel and red and blue cylinders are a balanced system, they will not move unless a small force is applied to them. The center of mass of the wheel and red and blue cylinders does not move if the system is moving or stationary. The dark disk on the edge of the white disk (on the table) in the picture is steel, and has a mass of 454g.
I placed the 454g disk on the red cylinder and allowed it to drop toward the floor. As the red cylinder (with disk) nearly reached the floor the motion was becoming violent.
Let’s assume that the motion is .6 m/sec. The total mass of the system is 4,210 + 4,210 + 2,300 + 454 = 11,174g. This means the system has a total momentum of 6.70 units. If all that momentum is given to the 454g (by the cylinder and spheres arrangement) it will rise 11 meters. The 454g disk was only dropped about .5 meters.
The Atwood’s is a machine that is used to prove F = ma, (or Ft = mv) the force of .454 * 9.81 N produces a change in momentum of the red and blue cylinders and the wheel, this is classic Newtonian Physics.
Jonathan
Posted: Sat Dec 20, 2008 3:49 am Post subject: re: energy producing experiments |
"NASA elected to use small rockets instead."
They use both: http://en.wikipedia.org/wiki/Yo-yo_de-spin
"what makes you think that they would have noticed it?"
If you were correct, then the math they do would give the wrong answer, which would, for example, prevent cameras and antennas from being aimed appropriately.
"You can change one circle into the other circle instantaneously without the application of outside force."
That's not the same as having weights fly outward, because there is no sudden change in the direction of the weights when the strings catch them. At that moment, the strings must exert a large force to change the direction of the momentum, and in the process a large portion of the momentum is dissipated in the strings as heat, so there is less macroscopic kinetic energy. It's like the weights hit an invisible cylindrical wall, and since some of their momentum is radial at that point, some of it is wasted. I have attached an illustration; the arrows are at the proper angle and relative scale for their respective drawings.
| Description: |
| Filesize: |
8.81 KB |
| Viewed: |
325 Time(s) |
Clarkie
Total Words: 13,452
Reputation: Respected
pequaide
Posted: Sat Dec 20, 2008 8:00 pm Post subject: re: energy producing experiments |
Yo-yo de-spin; reduce the initial spin rate of the 1420 kg spacecraft from 36 RPM down to 3 RPM in the other direction
Doesn’t the, other direction, mean they didn’t know what they were doing. They obviously didn’t have the math right. I see they used the process in the early 60s. Did they drop the process because they could not accurately predict the expected outcome, because they had an inaccurate mathematical explanation?
Johnathan: If you were correct, then the math they do would give the wrong answer, which would, for example, prevent cameras and antennas from being aimed appropriately.
Pequaide; It did give them the wrong answers. Missing by 3 RPM means they had no accurate control of the outcome. Accurate adjustment was done by the rockets. They probably had sensors that released the tether as the rotation slowed, and still missed by 3 RPM.
I can build different and new machines and hit the dead stop dead on, and they missed it by three RPM.
The string don’t come tight and catch the spheres as you propose, the tethers are always taut. The force in the tether may change but they never come thigh or jerk the sphere. Further if it were free the direction of travel of the spheres is always at 90° to that of the force in the tether.
pequaide
Posted: Mon Dec 22, 2008 6:36 pm Post subject: re: energy producing experiments |
One thing we know about the yo-yo de-spin device, used by NASA, is that all the rotational motion of the rocket or satellite is transferred to the small quantity of mass (3 kg) on the ends of the tethers. Let’s assume that the rocket’s rotation has been stopped by the tethered masses and the masses have been released. Suppose these two projectiles (simultaneously) then strike the rocket on a tangent line to its circumference at 12 o’clock and 6 o’clock, one projectile moving east and the other moving west. We should be aware by now that the rotational change (in linear Newtonian momentum) in the rocket will be proportional to the linear momentum change in the projectiles. There will be no angular momentum conservation, in fact the projectiles were moving in a straight line (they were released from their tethers) and had no angular momentum. We know that linear Newtonian momentum is conserved in this type of projectile collision because ballistic pendulums always conserve linear Newtonian momentum.
The block of a ballistic pendulum is not moving in a straight line it is rotating. It has a radius and a center of rotation. The block is rotating about its center of rotation. Blocks and projectiles can be made of hardened steel but they always conserve linear Newtonian momentum.
When the tethered masses are released by the tether they must have an adequate quantity of linear Newtonian momentum so that if they were to strike the rocket tangent and at 12 o’clock and 6 o’clock they would be able to return the rocket to its original state of rotation. Otherwise we violate a basic scientific principal of reversibility. This is an argument that NASA was improperly using conservation laws.
I built a cylinder and spheres machine (what NASA called a yo-yo de-spin device, I did not know they had used the concept) out of a three inch PVC pipe coupler. I got the cylinder to stop rotating when the tethered masses were swung out at 90° (to tangent) by adding more and more mass in the form of a 3 inch PVC pipe. I took the mass of the attached 3 inch PVC pipe (that made the cylinder stop rotating when the spheres were at 90°) and calculated it linear Newtonian momentum when rotating. I then cut a length of 4 inch PVC pipe that had the same linear Newtonian momentum (when spun) as the 3 inch pipe. I attached the 4 inch pipe to the outside of the coupler. I then spun the cylinders (3 in. coupler with attached 4 inch pipe) and spheres and released the spheres, as the spheres swung out on the end of their tethers the cylinder was stopped just as the spheres reached 90°. The top coupler with spheres (when spun and released) will behave in the same manner if a 400g 3 inch pipe or a 300g 4 inch pipe is attached. Actually the mass of the 4 in. pipe is at about 307g because of the thickness of the walls, the center of rotational mass of a 3 inch PVC pipe is at about 3.3 in. and the center of rotational mass of the 4 inch pipe is at about 4.3 in.
The linear Newtonian momentum of the 300g 4 inch pipe and the 400 g 3 in. pipe is about the same when being spun. But the angular momentum of the 300g 4 inch pipe and the 400 g 3 in. pipe is not the same when being spun. So the cylinder and spheres is showing that it responds to linear Newtonian momentum conservation not angular momentum conservation. This experiment is yet another argument that NASA got it wrong.
Look at Laithwaite’s experiment again. Are these not masses on the end of tethers? And what did he say was conserved? Linear Newtonian momentum was conserved.
I have independently timed the motion of the spheres as they have all the motion in the cylinder and spheres experiment, and linear Newtonian momentum is conserved.
These are a few reasons I believe that angular momentum was not conserved by the yo-yo de-spin device, as NASA predicted. I predict that NASA will not tell you the actual (measured) velocity of the released masses. They may predict what they though the velocities were, but they cannot even make the cylinder (rocket) come to a dead rotational stop. They obviously did not know what they were doing. They accomplished a task, but they had the math way wrong.
