| View previous topic :: View next topic |
| Author |
Message |
path_finder
Total Words: 244,524
Reputation: Highly regarded
Posted: Sun Mar 14, 2010 1:36 am Post subject: The summary of my latest studies |
Dear all,
Being far from home, and not able to build nor test anything here, I take the opportunity for sharing my studies.
The starting idea: the hypocycloid
As explained several times earlier the hypocycloid with a ratio of 2:1 is an useful mechanism allowing an alternative motion along a segment in correlation with a circular rotation.
See for memory this old post:
http://www.besslerwheel.com/forum/download.php?id=6371
From this important point, many ways are available now for use this property.
I don't know wich one has been used by Bessler but so many clues are related with.
Second point: a design in two parts
Again, as explained many times (and not only by myself): a single overbalanced wheel (taken as single primemover) cannot give any success.
We need a car and and horse (like said by Bessler), otherwise said:
- one part gives the energy
- the second part retriggers the first one
Please note that the combination of the gravity and the centrifugal forces are sufficient for this concept.
I'm convinced that Bessler used some basic technologies used at that time and no extra source of energy
Note also that this couple of parts can be doubled for a more efficient torque.
My intent now is to show a set of animations applying these two points.
The first animation hereafter shows the mechanism giving the two oscillating paths (reciprocator).
There are two drums: one is the main wheel (in yellow), acting as planetary.
The second (in rosa) is also centered on the main axis, acting as satellite.
The linkage between the both is made by four rollers (in blue) rotating at the inner rim of the main drum, linked together by the cross (in grey) wich must be absolutely fixed to the ground, allowing the main wheel (in yellow) and the internal drum (in rosa) to rotate at the same speed, but with an opposite direction.
The internal drum (in rosa) owns another hollow drum with a some teeth on the inner rim.
Inside this gear a geared satellite rotates at twice the speed of the other parts, giving two sinusoidal motion, one horizontal and one vertical, furnishing a reciprocator (only the horizontal motion is enhanced).
This two axle (located on two opposite positions of a diameter) are the attachment pivot linked to the pair of weights.
Some remarks about this first animation.
1. The hypocycloid consists in two parts:
- the planetary gear (in red, with teeth) is linked (rotates) with the main wheel.
- the satellite gear (in blue, with teeth) is free and its center is rotating around the main axis thanks a crank.
2. The grey cross supporting the four rollers must be fixed. If Bessler used this design, this could well explain the purpose of the hole at the bottom of the pillar (a way for verifying the exact position of the cross).
3. A correct positioning between the satellite and the weights is a mandatory for an effective motion of the assembly.
4. All dimensions are critical: if R is the radius of the main Wheel, the radius of the hypocycloidal gear is R/4 (the famous ratio 4:1), the radius of the hypocycloidal satellite (in blue) is R/8 (for the hypocycloidal ratio 2:1).
Only the radius of the four blue rollers (between the main wheel and the internal drum) can be of any dimension.
The next animation will show how the part in charge of the energy is acting, the most important part being the reference circle (in green) where are attached the linkers modifying the torque.
The third animation will be the combination of the both parts showing the whole assembly in motion.
Please be patient, this is a complex job.
Hoping this description is comprehensive enough...
Many thanks for your attention.
| Description: |
| Filesize: |
170.6 KB |
| Viewed: |
371 Time(s) |
_________________ I cannot imagine why nobody though on this before, including myself? It is so simple!... |
path_finder
path_finder
path_finder
DrWhat
Total Words: 88,230
path_finder
path_finder
greendoor
Total Words: 330,254
Reputation: Respected
Posted: Fri May 07, 2010 7:13 am Post subject: |
Pathfinder - I am in awe of your dedication, skills and craftsmanship. And yes - topless1 does look like some surreal alien council meeting ...
I wish you every success. This design looks very interesting, and gels well with descriptions of Bessler's wheel & statements. I seem to recall one witness say Bessler with what was described as a scissor jack item - maybe something similar to these.
I agree with your 'starting point' and 'second point' theory. I came to a very similar conclusion a couple of years ago when I started getting interested in Bessler, and I have yet to find the flaw in that chain of logic. In fact, I found some fascinating ideas from Milkovic (the reactionless drive, not the contentious 2SO) that have got me thinking about this theory again. (Might start a new thread on this idea, so as not to derail this thread).
As much as I enthusiastically endorse Pequaide's momentum logic, there may be some common ground between these ideas anyway. But i'm also coming around to the idea that Centrifugal/Centripetal force may well be a source of energy - as crazy as that sounds.
I can't say I follow how you plan to make energy with this design - but assuming Bessler was not a fraud, and assuming that current laws of physics have some loopholes yet to be exploited, you seem to be getting close.
If nothing else - you are a true artist.
| Louis Nizer wrote: | | He who works with his hands is a laborer. He who works with his hands and his head is a craftsman. He who works with his hands and his head and his heart is an artist. |
path_finder
path_finder
Posted: Fri May 07, 2010 4:26 pm Post subject: re: The summary of my latest studies |
Two shots taken during the building of the related wheel.
The first one shows the three plates A,B and C of the drawing above.
On the second one we can observe the excentered geometry of the weights for a clockwise rotation and the orthogonal position of the arm middle points.
Note the difference in the position of the strings with the purpose to obtain a full circular symmetry (unbalanced wheel) at the rest position of the stopped wheel (shot taken with the wheel in an horizontal plane). The next step is the implementation of the two bearings in the plates A and C, but there is a subtile trick.
| Description: |
| Filesize: |
41.08 KB |
| Viewed: |
276 Time(s) |
| Description: |
| Filesize: |
36.17 KB |
| Viewed: |
310 Time(s) |
path_finder
nicbordeaux
Total Words: 211,152
Reputation: Well respected
path_finder
nicbordeaux
path_finder
