Forum Index
BesslerWheel.com
Discussion Board
Log inLog in RegisterRegister SearchSearch BlogsBlogs Blog NewsBlog News PollsPolls FAQFAQ FAQWiki
Forum Index
Mechanical device of production of energy!
Page 1 of 1
Post new topic   Reply to topic    Forum Index -> General Discussion
View previous topic :: View next topic
Author Message
Mikhail
Total Words: 22
PostPosted: Thu Nov 27, 2003 8:08 pm    Post subject: Mechanical device of production of energy! Reply with quote
Drawings: ( PDF )
Drawings: ( 3D ) - ( At the end of page )
http://ingenrw.narod.ru/Andv1/Opi2_1.html
Text 01 10913 short version.
-1-
The present invention relates to a mechanical device of production of energy, immersed vertically, using elements with variable volume and the Archimedes force for its operation. The elements with variable volume will change their volumes according to the positions of the magnets being inside. The general outline of the principle is represented on the Fig.1 drawing.
According to particular modes of realization: - for argument?s sake, and according to no illustrated alternatives, the device according to this invention can comprise wheels, being able to carry two or several chains, which will be adapted better to this system.
The fixing of the variable-volume elements, two or several chains, will allow to balance their centres of gravity according to the points of fixing.
-for argument?s sake, and according to no illustrated alternatives, the device according to this invention can comprise flexible tubes, whenever we want to remove the effects of the pressure of air, being inside the elements during the change of volumes. We can connect them all in series between them by flexible tubes of sufficient diameters, to ensure the flow of air between them.
The annexed drawings illustrate this invention:
Figure 1 represents the device of the invention immersed vertically, its general outline of the principle, using the variable-volume elements, (whose variation of volume is carried out with the help of the magnets), and the Archimedes force for its operation.
Figure 2 represents a section of the diagram, of the variable-volume elements working with the help of the magnets, during the evolution on the left side (G) of the device (maximum volume).
Figure 3 represents a section of the diagram, the same element during the evolution on the right side (D) (minimal volume) of the device and turned to 180° according to the elements, moving on the left side (G).
For instance, figure 4 represents a section of the diagram of the same alternative of the variable-volume elements in horizontal position, during the evolution on the right side (D) of the device.
The device, according to the invention, allows the mechanical production of energy thanks to a change of volume of the variable-volume elements (5) and (6), immersed and fixed to the links of a chain (8) fig. 1 by their fixing clips (11) fig. 2, creating the difference of the Archimedes forces (f) and (F) on the left (G) and right (D) fig. 1 of the device, involving the chain in the direction indicated on the diagram by the arrows and the rotation of the wheels on their axes (3) and (4) fig. 1.
According to different modes of realization, we can fix the elements in horizontal position Fig.4, they will be balanced and effective, but they all must be identical. The variable-volume elements will change their volume according to their moving on the left (G) or right (D) fig. 1 of the device, according to the position of the magnets, being inside. The magnets of the inner rotor of each variable-volume element will be always maintained in the same orientation with the help of floats (7) fig. 1 or (1) fig. 2, fixed at the end of their lever arms (5) fig. 2, interdependent of the axle (12) fig. 2 of the rotors, carrying the interior magnets.
-2-
During the evolution of the variable-volumes elements on the left side (G) fig. 1 of the device, the magnets (2) and (14) are opposite the magnets (9) rotor fig. 2 of the same polarity.
The magnets of same poles have the natural property to push back each other and will thus cause the displacement of the moving parts (3) toward the outside guided by the stems (6) fig. 2, increasing the volume of the whole element.
The displacement of the moving parts (2), (3), (14) and (15) fig. 2 toward the outside is assisted by the pressure to air, being inside the elements. The displacement of the magnets (2) and (14) Fig.2 is limited by adjustable thrusts (4) and (7) fig. 2. The magnets (2) and (14) are connected to the stems (15) fig. 3.
While variable-volumes elements move on the right part (D) fig. 1 of the device, the magnets (2) and (14) with fig. 3 are opposite the magnets (9) of opposed poles, and since the magnets of opposite pole have the natural property of attract each other, that will cause the moving displacement of the parts (2) and (3), guided by the stems (6) fig. 3 toward the interior, decreasing the volume of whole element while compressing to the air inside.
The thrusts (4) and (7) fig. 2 are also used to avoid the friction and the contact of the magnets. The variable-volumes elements moving on the left part (G) are turned to 180° contrary to the elements being on the right part (D) of the device fig. 1, 2 and 3, the orientations of the magnets of the rotor will always remain unchanged, maintained by the floats in the same direction (orientation).
To oppose the pressure of water (P) according to the depth, the variable-volumes elements are filled with air under a certain pressure (p) fig. 3, being perfectly tight, to preserve to the air inside. The water tightness is ensured by the bellows (8) and of the joints (13) on the axle (12) fig. 2. The casing (3) and (10) fig. 2 or fig. 3 must be out of diamagnetic matter.
The free space containing air inside the elements, the volume of the floats, the length of the lever arms and the other parameters, must be determined by tests on a prototype.
The forces caused by the attraction or the repulsion of the magnets in their movements, represented by arrows (13) and (14) for the higher part of the device and the arrows (15) and (16) fig. 1 for the lower part will counterbalance one another and have no influence on the device.
Their influences will have a local action on the items (A), (B), (C), (D) fig. 1. If the device turns freely, the forces will counterbalance with the friction of the elements during their displacement in water, causing the stabilization speed.
To produce energy, wheels must turn at a very low speed, and to increase the output we must use particularly powerful magnets, able to produce important changes of volumes in the variable-volumes elements, therefore the difference between the Archimedes forces(F) and (F) on each side of the device.
Frictions of the elements during their displacement in water are proportional to the speed of their displacement.
The difference between the Archimedes forces on each side of the wheels (G) and (D), is proportional to the shifted volume of water.
This device is intended to produce a mechanical and ecologically clean energy, easily transformable in electric power.
Back to top
Jonathan
Total Words: 229,845
Reputation: Well respected
Well respected
PostPosted: Fri Nov 28, 2003 7:36 am    Post subject: re: Mechanical device of production of energy! Reply with quote
Didn't you already post this? Or are you posting it again, and this time with the claim of it actually, experimentally, working?
_________________
Back to top
View user's profile Send email
Total Words: 29,971
Reputation: Disregarded by some
Disregarded by some
PostPosted: Fri Nov 28, 2003 9:24 am    Post subject: re: Mechanical device of production of energy! Reply with quote
Hi Mikhail,
well done, you are a person who can look over your own edge of plate. Congratulations.
_________________
Back to top
View user's profile Send email Visit poster's website
Jonathan
PostPosted: Fri Nov 28, 2003 10:07 am    Post subject: re: Mechanical device of production of energy! Reply with quote
Quote:
over the edge of the plate
What does that mean? Let me guess, it is a German saying that when translated literally sounds weird.
Back to top
Mikhail
Total Words: 22
PostPosted: Fri Nov 28, 2003 12:02 pm    Post subject: Re: re: Mechanical device of production of energy! Reply with quote
Hello, Yes, I already announced that, but I have did not have the English text. Once that the friends translated the text for me, I put on set forum.
Back to top
Mikhail
Total Words: 22
PostPosted: Fri Nov 28, 2003 12:09 pm    Post subject: Re: re: Mechanical device of production of energy! Reply with quote
Georg Künstler wrote:
Hi Mikhail,
Merci beaucoup, Georg !
Back to top
Mikhail
Total Words: 22
PostPosted: Fri Nov 28, 2003 12:10 pm    Post subject: Re: re: Mechanical device of production of energy! Reply with quote
Hi Mikhail,
Back to top
Mikhail
Total Words: 22
PostPosted: Thu Dec 11, 2003 4:33 am    Post subject: Re: re: Mechanical device of production of energy! Reply with quote
Number of publication:
FR2828716
Principal classification CIB:
F03B-17/04
Back to top
Total Words: 493,290
Reputation: Highly regarded
Highly regarded
PostPosted: Thu Dec 11, 2003 5:52 am    Post subject: re: Mechanical device of production of energy! Reply with quote
Mikhail,
Do you have a long version patent text? PDF is only pictures which I can not translate. I would like a copy of text to run though Babelfish.
Very interesting!
Thank you.
Back to top
View user's profile Send email Visit poster's website Skype Name
Mikhail
Total Words: 22
PostPosted: Thu Dec 11, 2003 8:52 am    Post subject: Re: re: Mechanical device of production of energy! Reply with quote
I have only the text in French.
Back to top
PostPosted: Thu Dec 11, 2003 2:08 pm    Post subject: re: Mechanical device of production of energy! Reply with quote
Can you email the French text to me? I will translate.
Thanks
Back to top
Mikhail
Total Words: 22
PostPosted: Thu Dec 11, 2003 2:54 pm    Post subject: Re: re: Mechanical device of production of energy! Reply with quote
I already sent has:
Back to top
Mikhail
Total Words: 22
PostPosted: Sun Jan 04, 2004 10:03 am    Post subject: Re: re: Mechanical device of production of energy!
Back to top
Display posts from previous:
Post new topic  Reply to topic    Forum Index -> General Discussion All times are GMT
Page 1 of 1
Jump to:
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You can vote in polls in this forum
You cannot attach files in this forum
You can download files in this forum
Log in:         Remember me
Please click below to help support this website!
Google
