Forum Index
BesslerWheel.com
Discussion Board
Log inLog in RegisterRegister SearchSearch BlogsBlogs Blog NewsBlog News PollsPolls FAQFAQ FAQWiki
Forum Index
Mayday! Mayday!!!
Page 23 of 36 Goto page Previous  1, 2, 3 ... 22, 23, 24 ... 34, 35, 36  Next
Post new topic   Reply to topic    Forum Index -> General Discussion
View previous topic :: View next topic
Author Message
Aman
Total Words: 19,931
Reputation: Disregarded by many
Disregarded by many
PostPosted: Wed May 16, 2012 4:04 am    Post subject: Reply with quote Report Post to Admin
Thanks a lot Murillo .
Back to top
View user's profile Send email Blog
raj
Total Words: 47,764
Reputation: Appreciated
Appreciated
PostPosted: Wed May 16, 2012 5:44 pm    Post subject: re: Mayday! Mayday!!! Reply with quote Report Post to Admin
Hello everybody.
First of all, I wished Ken had applied a friendlier, forget and forgive attitude towards all our forum mambers and stayed among us.
Coming back to my gravity wheel design which Path_Finder has so gracefully animated on this forum for our viewing, I am humbly optimistic that there is someting good about the design.
The only thing left to be done to come to a final conclusuon is to build a working model.
I was hoping to hear from Ralph and A.B. Hammer if they have attempted a build yet or not.
I am trying hard to build myself. But I am having problems at the very start.
No conclusive build and testing of the concept can be done before having a proper 2:1 rpm ratio two wheels built. I have the 2:1wheels model, but they lack proper alignment and precisionsn due to no precision engineering facilities.
In order to bypass this problematic 2:1 rpm ratio wheels on one and the same axle but on seperate hubs as Path_finders animation, I am bringing some changes in the design of the wheels.
See Drawing below:
This time the larger (cylindrical) wheel has a diameter of sixteen units with inner rims of two units diameter.
The smaller wheel has a diameter of eight units with an axle of one unit diameter.
The axle of the smaller whhel rests and rolls on inside inner rims of the larger wheel.
Because the diameter ratio of the inner rims of the larger wheel and the axle of the smaller wheel is 2 to 1, that makes the smaller wheel rotates at twice the speed of the larger wheel when in motion.
The length of the arms pivoting on the outer rim of the larger wheel is eight and a half units and the length of the arms pivoting on the rim of the smaller wheel is four and a half units.
The rest of the design is just like in the original design.
The reason for this new redesigning is to make a built easier, avoiding the need of the very complicated 2:1 wheels gearing system on one axle, to get a 2:1 rpm ratio of the two wheels.
I would be so grateful to Path_Finder, if he could do me a great favour in making a animation of this new design below.
 Description:
 Filesize:  206.86 KB
 Viewed:  86 Time(s)
Back to top
View user's profile
path_finder
Total Words: 244,717
Reputation: Highly regarded
Highly regarded
PostPosted: Wed May 16, 2012 6:19 pm    Post subject: re: Mayday! Mayday!!! Reply with quote Report Post to Admin
Dear Raj,
I'm ready to make a new animation, but I did not understand well how this new design works. Please give us more explanations. Thanks in advance.
_________________
Back to top
View user's profile
raj
PostPosted: Wed May 16, 2012 6:41 pm    Post subject: re: Mayday! Mayday!!! Reply with quote Report Post to Admin
Dear Path_Finder,
It's so nice to hear from you.
This new design is expected to work in the same way as the original design.
The small inside wheel will be rotating at twice the speed of the larger wheel, except now, the axle of the smaller wheel, resting/rotating on the inside rims of the larger wheel, is vertically half a unit length lower than the axle of the larger wheel.
The movements of the weights are expected to follow roughly the same paths as in your original animation.
Just change the relative dimensions of the wheels' diameter and the length of the long and short arms and positions of the two axles, the smaller wheel below the larger, as explained above.
Back to top
View user's profile
Total Words: 928,307
Highly regarded
PostPosted: Wed May 16, 2012 7:49 pm    Post subject: re: Mayday! Mayday!!! Reply with quote Report Post to Admin
Raj,
As explained earlier, I commited myself to a build, I also stated that due to my health and a backlog of clients you would have to bear with me.
I have 'hands on' researched your basic design convincing me to invest in new material to construct a model based on your original dimensions. This has taken some time due to supply and demand of the material having to be back ordered. Then only to find that the first shipment was freight damaged and refused.
The replacement order was received and unloaded in my shop not over two hours ago of this writing. The order consists of two 49 X 97 X 3/4" and one sheet of 1/2" industrial grade MDF of 50# density. The overall finished diameter will be 48-1/2"...
I as P_F, question your latest improvements regarding the inner wheel axle being turned by the outer wheels inner rim. If as I understand your description this would call for a somehow secondary axle cutting the spokes of the primary.
Take two coins of the same denomination, placing them on a flat surface. Hold one in place with your finger and then rotate the second around the circumference of the first. You will soon discover that the rotating/revolving coin will make two complete revolutions traveling the circumference of its own diameter.
Back to top
View user's profile Send email MSN Messenger
path_finder
PostPosted: Wed May 16, 2012 9:08 pm    Post subject: re: Mayday! Mayday!!! Reply with quote Report Post to Admin
Dear Raj,
Really I don't understand the benefit to have the two axles separated.
For what purpose? It does not bring any improvement in the quest for the double speed.
Back to top
View user's profile
raj
PostPosted: Thu May 17, 2012 4:02 am    Post subject: re: Mayday! Mayday!!! Reply with quote Report Post to Admin
Dear Ralph,
I am sorry to be a pest.
I know you are doing your best. It's just that I am a bit impatient by nature.
Here's for you and Path_Finder, my attempt to explain how my new gravity wheel design is expected to work:
1. Assume we have two circles, one of one unit diameter and the other of two units diameter.
The smaller circle rests and rolls inside the larger circle.
See drawing below.
Now the smaller circle represents the AXLE of the smaller wheel and the larger circle represents the INNER RIMS of the larger wheel in my new design.
 Description:
 Filesize:  24.77 KB
 Viewed:  28 Time(s)
Back to top
View user's profile
raj
PostPosted: Thu May 17, 2012 4:05 am    Post subject: re: Mayday! Mayday!!! Reply with quote Report Post to Admin
2. This is how the smaller wheel looks like.
 Description:
 Filesize:  113.61 KB
 Viewed:  32 Time(s)
Back to top
View user's profile
raj
PostPosted: Thu May 17, 2012 4:09 am    Post subject: re: Mayday! Mayday!!! Reply with quote Report Post to Admin
3. And this is how the larger (DRUM) wheel looks like.
 Description:
 Filesize:  227.47 KB
 Viewed:  36 Time(s)
Back to top
View user's profile
raj
PostPosted: Thu May 17, 2012 4:12 am    Post subject: re: Mayday! Mayday!!! Reply with quote Report Post to Admin
3b. And its lateral view.
 Description:
 Filesize:  140.07 KB
 Viewed:  38 Time(s)
Back to top
View user's profile
raj
PostPosted: Thu May 17, 2012 4:26 am    Post subject: re: Mayday! Mayday!!! Reply with quote Report Post to Admin
4. Finally the lateral view of my new gravity wheel design showing how the weights will be positioned inside the drum wheel.
You will notice that there are two vertical compartments, right and left. there will be four weights in each compartment, to allow their easy rotational movements.
I hope my explanations are explicit enough.
I await to hear from you of what you think of this new design.
The only reason for this new design is to alleviate the complicated 2:1 gearing of the two wheels in the original design.
I expect the movements of the weights in this new design will follow roughly the same path as in the original design.
Only an animation of this new design by Path_Finder will prove or disprove my theory.
I await to hear from you both and from other forum members.
Thanks.
 Description:
 Filesize:  152.95 KB
 Viewed:  39 Time(s)
Back to top
View user's profile
raj
PostPosted: Thu May 17, 2012 4:47 am    Post subject: re: Mayday! Mayday!!! Reply with quote Report Post to Admin
You will appreciate from the drawing above showing the two circles, the amaller one is resting/rolling inside the larger circle.
Because of the larger circle and the smaller circle diameter ratio is 2 to 1, one revolution of the larger circle will make two revolutions of the smaler circle.
This is how this new wheels design is expected to achieve the 2:1 rpm ratio.
Is this explation plausible?
Back to top
View user's profile
path_finder
PostPosted: Thu May 17, 2012 10:16 am    Post subject: re: Mayday! Mayday!!! Reply with quote Report Post to Admin
Dear raj,
Now your suggestion is clear, and I will build very soon the new animation.
I don't know what will be the new motion after changing the axis position: I'm afraid we will loose the benefit of the balanced geometry and therefore (maybe) reach a keeling position.
Be patient.
Back to top
View user's profile
raj
PostPosted: Thu May 17, 2012 10:56 am    Post subject: re: Mayday! Mayday!!! Reply with quote Report Post to Admin
My dear Path_Finder,
I have a feeling that this new design will work better.
But your animation will surely prove me wrong.
Back to top
View user's profile
path_finder
PostPosted: Thu May 17, 2012 2:47 pm    Post subject: re: Mayday! Mayday!!! Reply with quote Report Post to Admin
Dear raj,
I deeply regret but your latest suggestion is impossible to build, just for basic geometrical reasons, like explained hereafter (see the drawing below).
As required the smaller wheel (in orange) has its axle (in orange) rolling inside a drum (in black/red) with a size twice this axle. This assumes the rotation speed of the smaller wheel (in orange) to be two times quicker than the main wheel (in black/red).
In the showed position (artificially chosen as start position) the attachment pins are A and B for the main wheel, and C and D for the smaller wheel.
The circles in green and red are the requested length for the two rods, the intersection points being where the weight shall be attached to the both rods.
As you can see there is two solutions for the top part of the drawing: one position has been drawn (in light and dark blue).
But unfortunately in the lower part there is no connection point available because the change in the center position of the smaller wheel does not allow any more such as intersection point.
The circles X and Y don't have any common point, as shown in the drawing.
 Description:
 Filesize:  6.91 KB
 Viewed:  41 Time(s)
Back to top
View user's profile
Display posts from previous:
Post new topic  Reply to topic    Forum Index -> General Discussion All times are GMT
Jump to:
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You can vote in polls in this forum
You cannot attach files in this forum
You can download files in this forum
Log in:         Remember me
Please click below to help support this website!
Google
