A runner ?
ovaron
A runner ?
Post by ovaron »
https://www.politik-sind-wir.net/showth ... de-bekannt
I am pretty sure that this or a similar design has already been tried out.
It doesn't look bad at first glance.
Has anyone tried such a design as a physical model?
Art
re: A runner ?
Post by Art »
If the "4-Feder-Schaltung / Spiegelfeder" in the drawing is a simple spring system and not a solenoid then yes I have tested that type of arrangement more than once .
The reason I tested it more than once with different designs was because it gives reasonably good results because of the low rotational inertia of the system and the minimal back-torque from the 'negative ' overbalance during reset .
However I never managed to get any overunity in any of the tests .
The way the 'Spiegelfeder' (?) is drawn leads me to believe the author intended the design to be bidirectional .
The way the diagram shows the reset to already have taken place at the 6 o clock position doesnt actually happen in the rotating wheel . Usually it occurs somewhere between 6.30 and 8 o clock depending on the strength of the springs , amount of weight and speed of rotation .
Its a nice design - because it gives better than average results , it feels nice to play with .
ovaron
re: A runner ?
Post by ovaron »
Thanks, Art. That's exactly what I thought, that the reset will start after the 6 o'clock position. That's probably why it doesn't work. Too bad.
re: A runner ?
However I must say; that is a love piece of technical drawing.
That is a standard we should all aspire to achieve.
