killemaces wrote:So what is the code?have you found it Oistein,Why dont ?is it in your question?Dont need high IQ to make a guess:)
I`m not certain that I fully understand your question. But I`ll try to answer.
So, yes, I have identified a secret system in Besslers work. It is not the kind of cipher as is widely know from an internet search or popular ciphers. It can`t be fed into a computer to make substitutes. And it is not some version of an acrostic system. It is more like several codes. A set of rules, methods and figures that need to be understood. It also points to other work, using the same methods, then those can be solved and applied, either to be able to progress or as a confirmation of similar methods.
The discovery made me realize that it had wider implications, and like Fletcher said, yes, he built upon things he learned or "stole" by secretly looking into others personal papers...
It starts as subtle, then it becomes beautiful and then finally "disturbing". And much of this becomes clear when combining MT and AP.
Yes, the code describes a mechanism and some mechanical parts, but just as much confirms the secret systems that the "worthy" intellectuals of the 1300-1700s knew.. and still know.. now under a new guise.. What he show, was not meant by his peers to be shared freely! Or else it would be known to us a long time ago.
Please don`t make me start a new round of excuses, why I do this, don`t share or just build wheel etc. Everything at a time. I had to choose, and finally chose to work this way, as I found this gave me the most chance to success. I will soon as possible publish part 1 of my project. (The codes nature and the historical implications) (I work with professional partners to make a deal and a serious plan for this, but that takes time). Later I will start part 2: Set date for full disclosure of Besslers mechanism according the codes, including deadline for replication. After that deadline, if successful building or not, all will become "open source" for potential readers. All codes, diagrams and variations.
I have not officially tested my IQ, that is not why I started this tread, but it was to show that you can find new fresh answers to problems, by combing already available information.
So the codes also work in that same way!
Let`s say I search the internet and all the books in history, I cant find a special value Z, it could be that the value was there all along because the people knowing "Z" always agreed to write X+Y, but never Z. Z can then be found and later proven by repetitions.
I found this to be the methods nature. So what you should seek is always what is NOT there. So Z is invisible, but X+Y is all over... I found that it all can be traced back to an intellectual quest..a secret that started long before Besslers time. (Bessler knew it, and even added a second level to it.)
This is reflected in the search for the invisible "stone". This was a big deal at one time. Is it a physical stone? a treasure? where is it? or is it a code? a metaphor? why is it invisible? Do you know what it is? and so on..
It could be (and was) used to describe, names, locations, "treasure map", a fraud, a geometric figure, mechanical parts, instruments, constellations, God etc. "The sky is the limit.."
