This is my wheel concept 2017, not Bessler's 1717...
daanopperman
re: This is my wheel concept 2017, not Bessler's 1717...
Post by daanopperman »
Happy birthday ,
Hi Raj
Of cause there are web bots scanning this and other sites.
So you may get some delayed tidings :-)
raj
Post by raj »
I like your zealous sense of humour!
No fear! You are here!
raj
Post by raj »
@ Agor95.
Simply keeping my work on records, for what it's worth.
raj
Post by raj »
As from today, I am 100 + % convinced my Auto Gravity Wheel concept is going to be a runner.
Right now, I don't know how long it will take me to show the world my proof of concept.
The proof when I get it, will appear first on this forum.
I am working on this concept for almost two month, non-stop, and I am overjoyed of my findings.
Happy birthday
raj
Post by raj »
I shall be receiving my Auto Wheel concept testing 3D computer simulation video, by next week, as second stage of my auto wheel project.
raj
Post by raj »
Proof of asymmetry of weights motion!
Weight in red is in dead centre of wheel, at highest point. of height H.
Weight in black is at the lowest point of height H.
Wheel turns 105 degrees clockwise, for weight in red to fall from highest point to lowest point of height H.
Wheel turns 75 degrees counter-clockwise, for weight in black to rise uo from lowest point to highest point of height H.
Silvertiger
Post by Silvertiger »
Yes...they are definitely asymmetric. OB wheels are always asymmetric. Raj, try to get it to work with one weight; two at the most. If it works with one, it will work with more than one. :)
raj
Post by raj »
Just confirming: Work on proof of concept is ongoing.
I'll show it here, if and when I find it.
In the meantime, I have found good indications from John Collins' and Silvertiger's postings on other threads, this week, that give positive signs in my Auto Wheel concept
raj
Post by raj »
Auto Wheel proof of concept computer simulation is going on slowly but surely.
One weight in asymmetric orbital path looking good, falling on one side of wheel and rising up on the other side and resetting back to starting point
https://www.youtube.com/watch?v=0OViSBm90ao
Now waiting for full proof of concept simulation.
No indication of a working concept yet!
ovaron
Post by ovaron »
@raj
Your "Auto Wheel proof of concept computer simulation" seems an animation not a simulation.
raj
Post by raj »
OK!
If you say so.
Does that make you happy?
I have sufficient experience to differenciate between a computer animation and computer simulation.
In this video, the mass of the wheel, the mass of the lever, the mass of the weight, the mass and TENSION of the spring and all forces acting, have all been synchronized to achieve this asymmetric rotational motion.
The wheel, in the video, has been given an initial, starting force, in the SIMULATION program, to get it to rotate, and it will eventually stop and keel.
The purpose of this SIMULATION, is to check if the weights will obey and follow the asymmetric orbital path as per the Auto Wheel concept.
This video is NOT an ANIMATION to prove anything.
I have NEVER tried to FOOL anybody on this forum, because that would be fooling myself.
raj
Post by raj »
To the very few here who are following my presentations.
You should know by now, how my auto wheel concept is expected to work. I think it can with (1) three levers/weights at 120 degrees intervals (2) four levers/weights at 90 degrees intervals (3) five levers/weights at 72 degrees intervals (4) six levers/weights at 60 degrees intervals, twelve levers/weights at 30 degrees intervals and even more levers/weights, but that would get too crowded in one wheel.
I am working on a twelve levers/weights proof of concept.
The video above is showing just one lever/weight, with all predesigned pre-conceptualized data, being rotated through 360 degrees, to ascertain the conceptualized asymmetric orbital path of the weight, that would provide the necessary unidirectional torque for the wheel continuous rotation.
So far, I am overwhelmed by David M simulation. It is behaving exactly as I conceived it some two months ago.
This is what I see in the above video: pictures for those who want to see what I see. culminating in my original auto wheel drawing.
The question mark: would there be sufficient torque?
I think ...YES!
raj
Post by raj »
continues...
