Do you know the super wheel
azimuthe
Re: Do you know the super wheel
Post by azimuthe »
I'm an avid of demonstrator, and tester.
All the sentences, hypotheses and considerations are not too interesting.
I try to reproduce as simply as possible the concept of the patent once the object in the hands the conclusions will be obvious
Hello azimuthe
It can get tiring reading through posts of low grade speculations etc.
So it is understandable to want better definition on more solid ground.
Apologies for any excessive writing on my part.
Most of my time has been building a demonstration and testing web sever too guide viewers.
So they can too see what is possible and also what could be built.
Building a physical device needs too happen by several viewers independently to start the process of changing
the current paradigm to a more positive one.
So do you have a component to displace the wheel in the previous images?
I have one complex Bessler like implementation. Also a really simple one which I am creating the image for at this time.
It would be good to see other viewers on the site submitting their examples for this component.
All the Best
The Adoption Barrier
Robinhood46 wrote: Fri Jun 24, 2022 10:43 am I'm pretty sceptical of the super wheel, however, i have noticed a similar behaviour with Algodoo bearings which give runners.
As i said previously, "is Algodoo showing us something we don't want to see?".
Can the same apply to the super wheel?
I reviewed your post from 30 May on the behaviour of Algodoo via the YouTube link.
I click on another YouTube submission. Then watched the item and read the comments.
The conclusion: what ever we do 1. do not uses magnets 2. have a device that accelerates and does mechanical work.
3. isolate the device from all external inputs.
After all that build as many as you can and publish every thing as far and wide as possible.
P.S. This is what people think https://www.youtube.com/watch?v=1hYYdmj ... el=TopTenz
All the Best
I have not been watching how this innovation has progressed.
Have you seen any developments on this subject.
