Hi agor95 !
I am talking ( and imaging…) a “common “ 2D(not3D…)/double pendulum , as you can see at :
viewtopic.php?f=1&t=1751&hilit=Double+stick+game
It can be controlled by hand (the so old Shadoof…) or soft ( Swinging sticks ) , but playing the same lever-pendulum.
The next double-pendulum (crank - coulisse ) proposal , we can see at :
https://www.geocities.ws/iacob_alex/Ine ... led033.jpg (pos.13).
…..is intended to be tested in relation with gravity ( possible “self”running ! ? ) and rotational
inertia ( possible new propulsion ? ! ).
Al_ex
“Fishing” inertial propulsion…
Re: “Fishing” inertial propulsion…
…..with a simple “lure”/temptation /(two way streets “sign “…) , at :
www.hajtech.hu/vibrator/sceltavibratoree.htm
…..so , we can play inertia as a TO & FRO linear/bidirectional motion.
Now : how about an unidirectional…one way “street”…TO motion…playing a simple game with inertia/mechanic’s first law ? !
Al_ex
Al_ex
…..is like a manner to understand the motion of a fish in water and simultaneously in inertia (internal and external reaction )….but the fish know it , and takes all the advantages of swimming .
If we intend to move to and fro , with the help of two rotors /eccenters ,we have it… a variable linear force can be produced by centrifugal force when properly controlled ,as :
www.hajtech.hu/vibrator/sceltavibratoree.htm …it’s easy to imagine and test a pulsatory motion due to paired rotors.
The next and only step is a kind of ac/dc evolvement…as a possible unseen inertial “sail push” ? !
Some people (R.Cook/1987) made a proposal , between others , at :
www.rexresearch.com/cookip/cookip.htm
In my opinion , we must find a simple “style”(like a fish in water…) to play inertia…
Al_ex
Al_ex
…..starting with an electro-mechanical proposal on youtube (Icps/inertial centrifugal propulsion system ) , at :
https://youtu.be/2v1wuPWkw3E?si=NNcmbOgq5kQrqp5K
…..then as a simplified mechanical ( only ! ) system ,at :
www.geocities.ws/iacob_alex/Inertial_Ro ... led033.jpg (pos.13)
…..also…as a simplified sliding crank mechanism ( rotating and sliding connecting rod ) , at :
https://www.britannica.com/technology/s ... -mechanism
…..if we “redesign “/modify a rotary vane pump concept , at :
https://en.wikipedia.com/wiki/Rotary_vane_pump
…..keeping in mind to obtain an one way centrifugal pulsatory vector , as a result of two paired variable rotors….flapping inertia.
Al_ex
Al_ex
…..with the help of a particular two counter rotating pendular arrangement intended to obtain a pulsatory oneway vector ,as :
www.geocities.ws/iacob_alex/Inertial_Ro ... led025.jpg (pos.38) …..an assembly , at :
…..the simplicity of a centrifugal assembly ( crank = differential pendulum )/pulsatory centrifuge
www.geocities.ws/iacob_alex/Disclosed_e ... ab0013.JPG
By the way : we can play the variable arm/“differential/end to end “ pendulum as a rotating - sliding fulcrum lever , or the primary mobile “stick”/lever.
With this particular lever , we can play not 1g (gravity) only…think about possible many “g” centrifuges with the inertial property of the space.
https://www.amazon.co.uk/AERZETIX-Break ... B0BTHZYJ66
Al_ex
Al_ex
…..as an artistique effort to create a human connection with the real world, at :
https://openart.ai/community/W2D8zkvOvg29vUfXOZj0
https://openart.ai/community/HinL3EYogrPCc4t28MUa
Al_ex
Al_ex
