Unbalanced pendulum…
…..this time as an one -piece “compound” pandulum and a particular fulcrum , playing momentum and inclined plane phisics , at :
www.geocities.ws/iacob_alex/Some_Drafts/text050.jpg
I hope that a simple test can clarify the validity of this proposal…
Al_ex
Al_ex
Re: Unbalanced pendulum…
…..or as a possible continuous unbalanced lever , due to a “particular” hinge-pivot :
https://www.dimensions.com/element/risi ... door-hinge
Here , dimensions can be a main point…
Al_ex
Al_ex
It is difficult to present a concept in 2D where three dimensions are required.
I had a two hinged doors [soloon doors] and have several drop doors.
Drop door are like the one you show but have normal door angle of opening.
These hinges increase in length while they operate.
So are you using the middle mass to open the hinge thus increasing the length to cause overbalance.
…..this time as an one -piece “compound” pendulum and a particular fulcrum , playing momentum and inclined plane phisics , at :
Al_ex
Al_ex
www.geocities.ws/iacob_alex/Some_Drafts/text026.jpg
We can use a modified rising butt door hinge , as : https://www.eBay.co.uk/itm/232597307302
Al_ex
Al_ex
Hi
I downloaded your image and enlarged to see your 2008 concept.
So the implementation is by moving the main beam of centre to the right by gravity moving the central mass.
Great idea!
Did you build it since then?
Great idea!
Re: Unbalanced lever….
…..due to a 90 degrees switching pendulum ,every half turn , as a proposal .at :
…..with the help of a modified rising butt door hinge , starting with :
https://www.dndhardware.com/What-is-ris ... 50700.html
We must accept that any proposal will be “tempered” with the reality…
Al_ex
PS for agor 95 : no , sorry …
Al_ex
Still a good idea. There is that tricky transition issue of the arm being out and needing to be pulled back in.
Also the middle mass dropping and needing to be lifted.
A pain to all that explore 'The Quest'.
All the Best
Бухгалтер курган
Весь необходимый пакет документов подготовили к указанной дате Бухгалтер в кургане . Перевод ООО/ИП в Курганскую область под 1% УСН вместо 6% или 5% УСН вместо 15% .
Курган бухгалтер
Работаем с 2009 года Бухгалтер курган . Перевод ООО/ИП в Курганскую область под 1% УСН вместо 6% или 5% УСН вместо 15% .
Курган бухгалтер
Бухгалтер в кургане
Нравятся адекватные сроки выполнения заказа, цены за услуги вполне адекватные Бухгалтер курган . Перевод ООО/ИП в Курганскую область под 1% УСН вместо 6% или 5% УСН вместо 15% .
В кургане бухгалтер
Весь необходимый пакет документов подготовили к указанной дате Бухгалтер курган . Перевод ООО/ИП в Курганскую область под 1% УСН вместо 6% или 5% УСН вместо 15% .
Курган бухгалтер
Наши специалисты – профессиональная команда, способная решать задачи любого уровня сложности Курган бухгалтер . Перевод ООО/ИП в Курганскую область под 1% УСН вместо 6% или 5% УСН вместо 15% .
Курган бухгалтер
Работой компании очень довольна, теперь ее услугами пользуюсь постоянно Бухгалтер курган . Перевод ООО/ИП в Курганскую область под 1% УСН вместо 6% или 5% УСН вместо 15% .
