Posted by ovyyus (203.20.229.2) on June 27, 2003 at 18:06:39:
In Reply to: MT 138 posted by David on June 27, 2003 at 17:44:20:
Hi David,
I agree that A & B appear to be different elevations of the same thing. Based on your assessment then, what is the device?
BTW, what you refer to as balls or weights on the side of A have white centre dots which Bessler usually used to depict pivot or hinge points. That might suggest that A & B are intended to function in connection with something else.
: Drawing B is a 90 side view of A. The Y shape at the top is a point of reference to illustrate the two parrellel side angles you can't see from tyhis perspective-opened up. The balls, what some have refered to as weights, are actually the part that is held to work the device, like the two illustrations in the center.
