Posted by Michael (199.60.107.1) on September 27, 2003 at 11:03:14:
In Reply to: Re: Off topic- Mike, thanks posted by grim on September 26, 2003 at 18:44:53:
: Thought about something else to on that old rig. If the violence is due to the bottom weights being raised off bottom, why couldn't one let them stay at the bottom rim and
: raise them at the top, with the same lever/counterweight, with a stop to only allow the counterweight/lever to raise and drop just so far?
: If topheavy yields positive results, what's the diference if you raise the bottom weights or raise the top ones to achieve it?
: In other words, instead of 'Techstuf's weights drooping at the top, raise them up a distance from the axle greater than from axle to bottom weights.
Sure that sounds good.
