Posted by Patrick (66.185.84.206) on October 09, 2003 at 18:31:26:
In Reply to: 22.5 Degree Picture posted by Patrick on October 08, 2003 at 19:51:05:
These are all good concepts about the 22.5 Degree Picture. Stewart, I especially like your idea of superimposing it over the other images for clues. Now I will tell you what the image means to give you a head start in finding the complete solution. Bessler has removed the covering of his wheel in those sections to show you what is inside. He speaks from the grave and says, "Look, even if I remove these three sections, can't you figure it out now?" But you may argue, "Hey, there is nothing there, just blank white sections!" That is correct my simple little friend, there is nothing in the wheel in those sections; I repeat, nothing, nada, zip. Get it? Now you should have a clear idea of where to start, but you better hurry,.. my experiments are almost complete.
If you have read this posting and would like to comment, please select one the following pre-printed responses and just indicate by letter your reply to save time.
A) That is a ridiculous idea, you must be insane.
B) I don't care, perpetual motion is impossible anyway.
C) That is just another example of the eccentric trouble force with the storkraft energy. It gives the result of the golden link to the Bessler solution that he was releasing of the gravity; same again as you will see before.
D) I thought of that a loooonng time ago, that's an old idea and doesn't help me at all.
E) I know that, I already solved Bessler's wheel, I just haven't had a chance to build it yet so go away.
F) Forget that, I'm goin to Bessler's hometown to find it, yeah!
best regards, Patrick Doucette
