A perpetual motion allegory...
.....as a delusion , at : www.lettl.de/pics/g191.jpg
but as a hope , also...at : https://m.youtube.com/watch?v=-tvaKg3X4TE
Al_ex
Al_ex
re: A perpetual motion allegory...
Al_ex
interesting video and music for an inspiration. I have 3 weeks and a day and my operations that I have to go through start. This means no armor construction for a while. But with help from my sons. I may be able to do some wheel work and I will finish my next videos to post. The second part to this one and some new designs.
https://www.youtube.com/watch?v=Ny7O7bAn2uU
Hi AB !
Firstly , I wish you a good health and success for the next video.
Personally , I am interested for your development of :
https://m.youtube.com/watch?v=5I4NDGcj1UA
Al_ex
Al_ex
Hi AB !
My suggestion for your test-stand : as a starting experiment , you can try the most simple arrangement of variable / oscillatory leverage , at :
www.geocities.ws/iacob_alex/Some_Drafts/text032.jpg
Open to view , it's a pair of levers operated by a possible continuous gravity unbalance...on the same side of the fulcrum...if we take into consideration the continuous moving support under the beams , and the corespondent variability of reactions on a first degree lever.
Al_ex
Al_ex
Hi AB !
As I see at : https://m.youtube.com/watch?v=A5pPaTqd-4w you play two inverted pendulums...not two simple supported beams.
Al_ex
Al_ex
Al_ex
Look at this photo and you will see I didn't start out with the mounts I added later that shows on the video.
http://www.besslerwheel.com/forum/downl ... er=user_id
The fact of what I am doing is replacing those I added with the new device of inversion. Then we will see how it rocks. ;-)
Hi AB !
The essence of this test is to play the variance of two heavy simple supported beams ( Class 2,3 levers) on a "weighting device" (Class 1 lever) , that is brought into a possible continuous non-equilibrium .
Take a simply supported beam in a fixed point and try to "feel" in your hands your effort in different points...or a variable leverage.
With two simply supported beams you can make a "comparison" and use it as a torque difference on a common lever.
The problem is to put "at work" this torque difference /gravity unbalance...
Al_ex
Al_ex
Hi AB !
Some people call this type of variable leverage as an "unbalanced weights scale " , you can see at :
https://m.youtube.com/watch?v=qsoUemkAm ... e=youtu.be
https://m.youtube.com/watch?v=VuMkLBtUf ... e=youtu.be
https://m.youtube.com/watch?v=_gAchuS8SyU
The general idea is the same ( unbalance on a scale/lever) , but the problem is to obtain "self" motion ( due to a continuous gravity unbalance on the same side of the fulcrum ).
Really , an idea can be the root of creation...but , maybe it "grows" better when transmitted to another person...
Al_ex
Al_ex
