Grease power
Re: Grease power
My doodled concept for MT138 looks at the toy page that shows two men holding hammers hitting a drum, I think. I took the literal frame of the drawing and put it along the cross bar of a wheel. I made 4 cross bars, up and down and across horizontal and two diagonals. Pretty basic cross bars to start with like how you would cut a pizza possibly. The frame of the hammering people looked like the tip of the hammers is the weights and the rest of the drawing was the frame of the device. The weights at the tip are balanced but because of the connection between the right angles (the hammer is shaped like a right angle) if it's tipped to one side of the other the right angles between themselves will push on the bar unbalanced and tip it to the one side it's slightly overbalanced on. This is really cool. A light push or incentive to move will cause it to slide to one side the rest of the way, these two right angles connected by a bar beneath them that is the frame of the MT138 hammer men as I believe I see it.
A 4:1 gear connects to the leg of one right angle to the opposite side of the cross bar to one of the legs of that right angle lever by a string. The string hangs loose as the overbalanced side's larger gear releases extra string. The mechanism on one side closes and becomes a box to move the hammer men on the opposite side but not all of the way, the remainder of the hammering happens because the two right angles are out of balance some and it will fall the rest of the way on its own because the bar between the two right angles is pushing it out of balance. The two right angles on these mechanisms are only balanced with the weights are together in a box shape. When they separate even a little on a horizontal surface they will be compelled to move by the bar connecting them together the rest of the way out of balance. The loose string will wind as the driving right angles become a box and at the last part of the box creation it will tug on the opposite right angles setting them out of balance. This is probably why Bessler emphasized the moment the weights come together the wheel will be overbalanced because the weights come together and just before they come together they tug on their opposite mechanism which is then set out of balance and as it's its own out of balance state as a mechanism if it's out of balance even a little. The large gear connection pulls a loose string tight and then pulls the mechanism the rest of the way.
Re: Grease power
I'm curious about pyramids also. I think that volume distribution will change temperature inside of a pyramid if the pyramid is insulated. So stacking one pyramid on another will concentrate heat, into colder or hotter zones. A long series of connected pyramids cold have a very cold or very hot location on the closed end and on the open end if there is a consistent heat source there, like underground dirt, that temperature will be normal for itself. So an underground series of connected pyramids could secretly hold inside of them under their insulation extreme heat or cold.
I actually believe that I discovered directional freezing conceptually and shared it with a lot of people before it was "discovered" in 2015 and began being used in cocktails because I was talking about the thing long before 2015 but I never did an experiment. Also, I believe that it is a miracle. I think that directional freezing could remove mercury from water. My insight into the concept was in fact ice burgs. I believed that ocean ice comes from directional freezing, and not ancient frozen glaciers. Directional freezing as it's known today is the event where insulated containers can be open on the top and freeze the top half of the water clear known as Clear ice, that is popular for liquor now. My purpose of it was more than just liquor, I think this is a serious water purification method. But I have done no experiments yet on my concept that I think I really invented and just told too many people about so someone else is taking credit for it. I tell people a lot of things and they forget about it because apparently I am not very interesting to the people I know- however some I talked to must have spread my idea until someone else was able to take credit for it and 100% of the people I interact with are not very friendly to me so they might all deny they heard the information from me because they don't remember because they don't care or because that person is the actual person who spread the information and doesn't want me to be able to take credit for it. Just from my personal experiences it looks like the idea was stolen from me. And I have no evidence other than my intense belief to back me up on this because I basically have no friends almost.
I think that the Earth is in danger from geothermal energy use. Since, in my opinion there might not be nuclear material heating the Earth by decay. I think that Earth's heat and all planets heat is probably coming from gravitational pressure. So it has a constant heat source under pressure of gravity. I think that the planet collects this heat and spends it on gravity and gravity cools the core. So there is a finite resource here, gravity and heat, that we will deplete and cool the core with when we extract heat, or I suggest you believe because I believe gravity wheel's like Bessler's would also cool the core. I think that additional heat goes into the planet from sunlight energy but this is also spent on gravity. What's my solution to protect the Earth from Geothermal extraction energy use? Geothermal air exchange during summers. The hot air goes underground and is absorbed by the Earth and cooler air enters the atmosphere from the ground. This should put more sunlight energy into the Earth, and maybe restore the gravitational heat balance that is being offset by geothermal extraction use of energy.
My theory about Parkinson's disease is that it's a dietary lust induced disease, because if you drink enough extra tart lemonade and extra salty potato chips it will cause the disease and that all people with Parkinson's disease probably did this. So instead of someone being vulnerable due to a genetic or biological condition, it's actually that they are vulnerable to their dietary lusts. And that specifically it's tart lemonade and salty potato chips. I hypothesize that removing all cellular level potassium in the body somehow would reverse or stop the progression of Parkinson's disease because I think that it is the specifically the potassium clogged somewhere biochemically that is keeping the disease and its progression.
