Distant action...
iacob alex
re: Distant action...
Post by iacob alex »
Hi Georg !
Again : www.geocities.ws/iacob_alex/Some_Drafts/text048.jpg
1-5: we have a continuous (0*-180*,then 181*-360*) full turn and rotational motion storage (see the heavy hub) due to an incessant positive gravity acceleration ( torque difference on the same side of the fulcrum ).
6: here is the single "point" (to "reshape" the starting unbalance ...due to a distant action ,maybe...) a.s.o.
Al_ex
Hi iacob Alex,
the Trebuche alone will not work, again you Need the second System.
Who will lift the weight at 12 o'clock ?
Your Version is comparable to
https://www.youtube.com/watch?v=fxe55EtbR8Y
iacob alex
Hi Georg !
"the Trebuche(trebuchet...) alone will not work"...I agree, we must charge it in some way.
"again you Need the second System"...I agree ,we need to charge it,but not manually this time.
"Who will lift the weight at 12 o'clock?"...I hope we can use the centrifugal/launching throw , alike that of the trebuchet...supplied from the rotational motion storage of the heavy hub.
"Your Version is compatibie to...(youtube/Leonardo)"...with 7 variable arms is an older(~1250)proposal (Villier's wheel )...my outline is a lever (a "minimal wheel" !? ) with a single variable arm (it can be a trebuchet short abstracts...) and a heavy hub .
The only problem is the top point unbalance , as a "self".
By the way , we can use the "Search All Forums " window of this board related to "trebuchet" (115 matches) and "distant action " ( 28 matches).
About the top point possible "self" restarting unbalance...I hope there are a
lot of possibilities !
"In all things it is better to hope than to despair"(J W von Goethe)
Al_ex
