MrVibrating wrote:...coming back at this from the Bessler end of the problem:
- A central tenet of this thesis is that the only way to generate excess KE from within the framework of classical mechanics is by exploiting the standard 1/2mV^2 function, but in application to an effective asymmetric inertial interaction, and resulting divergent or 'runaway' inertial frame of reference. Therefore, so the theory goes, if Bessler's witness testimonies are genuine, then this must be, by definition, what his machines were doing. There simply are no other contenders for a candidate energy-generating principle, because both inertial and gravitational interactions are definitively symmetry-bound within their own domains; ultimately, because mass and gravity are constants, not time dependent. Only an effective violation of Newton's 3rd and thus 1st laws could introduce the requisite axis around which a time-dependent input / output differential could be made manifest, even in principle. It really is this elementary.
- All of the evidence for Bessler's wheels is consistent with this hypothesis; their requisite verticality, uniformity of rotation of complete system - ie. including whatever internal mass was being used for reaction mass, since there were no external stators, and Bessler himself confirmed that "in a true PMM, everything must go around together"... in a single statement, eliminating any other possibility (for instance, such a condition would not apply to a putative gravitational energy asymmetry).
- We are thus looking for a gravity-assisted effective N3 violation - ie., using gravity to cancel or invert the sign of counter-momentum. Doing this is trivially simple; it happens automatically when we apply a 9.81 N force vertically between two inertias, at least one of which is subject to gravitation. There really is no ingenuity or complexity involved in this feat, it's just a bog-standard inertial interaction, and a bog-standard gravitational interaction, coupled together at the same time. This simple, basic condition causes the inertial interaction to produce unilateral momentum.
- To grab that asymmetric distribution of momentum, and consolidate it over successive cycles, requires literally hammering it into the net system, via controlled collisions. That is, the accelerated mass, from the asymmetric inertial interaction, has to subsequently share that momentum back with the 'non-accelerated' mass; speeding it up a little, and slowing itself down a little, meeting at a new, higher, net system velocity. And so over successive cycles of reactionless acceleration and collision, the net system momentum drags itself up by its bootstraps.
- It is therefore a foregone conclusion that the impacts heard emanating from the descending side of Bessler's wheels were performing this function.
- Either the net system was being unilaterally accelerated against these weights, or else, these weights were being unilaterally accelerated against the net system. Either way, the subsequent collisions were consolidating that momentum asymmetry into a net rise in system momentum per cycle.
- Wolff's impression was that the weights somehow landed with more momentum than would be endowed by their falling.. ie., that their descent was powered.
- The implication is thus that there's some way of propelling a weight downwards, either without applying counter-torque in the first place, or else, actually inverting the sign of that counter-torque, or its resulting counter-momentum. Either way, gravity has to be the key to achieving the asymmetric inertial interaction that was responsible for producing the asymmetric momentum distribution.
- All of these conclusions seem self-evident and axiomatic. Everything seems to cross-reference consistently. We really do have all our ducks in a row here.
...so maybe the biggest clue, with regards to how best to proceed in the context of this knowledge, is Wolff's impression of excess momentum exchanged in these impacts on the descending side of the wheel.
We also know that some kind of internal store of PE is required, to power these inertial interactions. And accordingly, Bessler was also seen to preload a spring by pushing downwards into the wheel. This would imply that the spring was acting in the radial plane, and while it remains possible that its attached loads were operated in some other plane via pulleys, the simplest implication would be that they supplied an effective centripetal force to a radially-translating mass... Something that is forced inwards, against any inherent inclinations to stay outwards..
Thus the lucky 8 ball of my dubious intuitions would seem to be flailing in a clear direction - what if these asymmetric inertial interactions are initiated in the first instance by radial translations; ie. the 'ice-skater effect'?
I've noted previously how these 'inertial torques' are effective N3 exceptions in their own right - the torque is caused by conservation of angular momentum in a changing MoI, without an accompanying instantaneous counter-torque being applied back to the system; rather, the corresponding counter-torque is delayed until such time as the mass is moved back out to its former radius.
Hence a gravity-assisted exploit of the ice-skater principle would seem a strong candidate solution. As such, there would be nothing magical about the weights landing with momentum in excess of their corresponding GPE, as suggested by Wolff. Rather, the trick would lie in gravitationally attenuating their deceleration upon re-extension...
For example, what might happen if the masses are both retracted and re-extended on the descending side of the wheel? So, being forced inwards whilst descending, to then travel back up and around at that retracted radius, and then only being re-extended when they arrive back for their second descent... and so each mass moving in and back out on alternate rotations, and only changing radius during the descent phase..?
As such, one full cycle of one such interaction would require 720° of rotation. We could slide the weights in and out upon independently-articulated armatures, able to rotate with some degree of independence from the wheel and each other... but also, able to be locked to the wheel.
For instance, suppose we pull a mass inwards whilst its armature is locked to the wheel, and so applying 'inertial torque' to the net system... then when the same mass comes back around for its second descent, its armature is unlocked from the wheel, and so allowed to decelerate as the mass extends - and be subsequently re-accelerated by gravity - independently of the net system..?
Whilst such inertial torques conserve net momentum (indeed are caused by it), perhaps their juxtaposition with gravitational torques provides opportunity for some kind of 'rectification' trick..
For now, we still have an outstanding candidate in the form of the active-lift/passive drop variant of the above configs - i think - charging the flywheel when the weight's rising, rather than when it's falling.. but like i say, this seems mechanically awkward..
Incidentally, there's another silly idea that's been playing over in the back of my mind - throw a weight upwards on the descending side of a wheel, to be caught by an identical mechanism descending around the wheel from above.. or else, a ratchet mechanism. Sorta like a hamster wheel effect, but with a really fast hamster, like maybe a Roborovski, on quite a heavy wheel, type stuff..
The interesting point would be that the counterforce from propelling the weight upwards produces positive torque on the net system... meanwhile, gravity is effectively reversing or at least mitigating the counter-momentum being applied to the hamsters, i mean weights, braking, if not fully inverting their 'upwards' momentum. It's ultimately a different shot at the same fundamental concept, of accumulating asymmetric momentum, causing a corresponding input work / output KE disunity.
One of these approaches, or maybe a slight variation on them, has to be the form of the solution. Each eliminated possibility leaves an ever-dwindling range of alternatives, stepping stones to an inexorable conclusion.. the question is not 'how to create KE?' - nature already furnishes us with a perfectly adequate mechanism, KE=1/2mV^2. The issue is simply how we go about sharp-elbowing our way up the V^2 line. We already know, by definition, that this implies playing with inertial interactions - you wanna accelerate something, you need to do so against something else.. thus the possibility of a KE gain reduces to applying gravity to manipulate the conservation of momentum of an otherwise-closed system of interacting masses... create a divergent inertial FoR and from thereon you can't help but 'create' KE. Can barely move without doing so.
Thus i maintain that this is a perfectly simple problem, eminently tractable, with an easy, straightforward and totally self-explanatory solution. We're just one Mendeleyevian dream, one TMS or peyote session away from seeing what's right in front of us, i'm certain of it.. and there's really very few pieces to the puzzle - the input and output integrals of an inertial interaction, and of a gravitational one; integrals of momentum especially, over those of energy in the first instance. From that asymmetry, we board the V^2 escalator to free KE..
Good Stuff Mr 5 on P5 of P5 ! : )
Yes , I think If we get Besslers wheel going mechanically , - This is how it will be explained !
There appears to be a problem in the computations though if I'm seeing it clearly in your post dated May 1st.11.37Am.
Quote :- "- since the rotor is brought to a halt, we can reset its MoI for free, sans CF or counter-torque (ie. incurring no negative inertial torque from moving back out) "
-----Dunno about that !
Changing the MoI of a mass or system necessarily involves an energy consumption involved in moving the component parts of the weight or system either towards or away from each other around their common locus.
There is a cost to move a mass a finite distance in space . Think - force needs to be applied to mass against its intrinsic inertia to give it momentum to get to it's new location (relative to the common locus) and then after a sufficient interval a force to counteract that momentum and bring it to a stop at its new location must also necessarily be applied .
The energy for this movement can only come through the weight / system's attachment to the wheel .
I believe the energy transfer must happen through the interaction of the "inertias" of the weight or system (not the MoI of the weight or system but the "intrinsic" inertia of the mass or system ) in direct reaction with the "inertia" (momentum) of the wheels angular rotation.
Quote :- " we can reset its MoI for free" , - - I'm pretty sure that can't be done , But the actual energy cost may be small enough that it still allows you to get a gain .
I have no idea how you would calculate or sim it though , - just thought I would pass the problem on to an expert who might :)
