Posted by SK (218.145.25.11) on June 05, 2003 at 10:52:47:
Hi everyone.
As I mentioned before I am doing with 80cm diameter wheel.
Yesterday I can see the power of my wheel.
In my wheel I use 60mm diameter 30mm tall cylinderical weights.
I realise the angle is the key of the structure.
So I decide to order new angle controller today.
Did you see the Bessler bearing diagram with black and white color?
I am fully understad what it mean.
The diagram means many things.
Do you know the angle of the white area?
Do you know the angle of the black area?
If you can use CAD draw and measure the angle.
Do you know the sum of angles of the black and white area?
That is not 360 degree. That is 357 degree. Do you know the reason? Do you know why 3 degree disapeared?
It means many thing.
I am almost done now, so I am telling you something.
Today I finally fully understand the Bessler's bearing diagram.
The diagram shows very critical hint.
Please look carefully the black and white area.
Weights get power from their own swing.
Do you know what is the power source for swing?
I know the power source. I saw the power. I felt the power.
Last time I was doing with 40cm diameter wheel.
But it was very difficult to see or feel the power.
After some experiment with 80cm diameter wheel I can see it.
I will give you some information now.
Weight size is not related to the rotation.
But the shape should be cylinderical.
How heavy the weights are.
How strong the springs are.
There is only two factors.
If weight is heavy the spring should be strong.
Very simple.
Another thing is not variable.
Everything is fixed or adjust free by some calculation.
Maybe next time I can send more information to you in here.
My both hands(fingers) are almost paralyzed by 3 months experiment.
I think during that period I did more than 100 models.
Finally yesterday I see the power of the gravity.
Today I feel very happy with my wheel.
And I am thinking the IMPROVEMENT.(Next stage)
More hint for you:
In the wheel building, the most important thing to consider is friction and accuracy.
If you cannot overcome friction, the wheel will never rotate.
I adapt some parts like LINEAR GUIDE.
That is some expensive. But If you want to get or see the power,
you will need friction free parts.
Accuracy is for the balance.
Sorry about Too many words.
I have many things to tell you.
But I did not succeed yet until today.
After succeed I will tell you more, after apply PATENT.
PS. I have been applied patent my IDEA, but it was proved not working by yesterday experiment.
My new DESIGN will be applied patent next week.
If you have any Question, please let me know with EASY English.
regards SK (Seokkyun in KOREA)
