Posted by Darren (208.143.232.66) on June 10, 2003 at 09:30:52:
In Reply to: Re: Springs posted by grim on June 09, 2003 at 21:28:26:
: : I'm wondering if other people are using springs in their machines. Grim, Darren? Springs might be related to the overunity principle which produces energy. Just a thought.
Although at times I think I may have confused people by absentmindedly mixing details between them, I have basically only talked about two different designs I've worked on. Design I exhibits OU and is moderately complicated, Design II was simpler, fit the Bessler clues perfectly... and in the end did not show OU.
My Design I only uses a single spring. It does not use it in the way you'd think, and technically it's not even necessary, but for now it's in there. Design II used multiple springs that were attached to just about all the weights... but again... that design didn't pan out so...
In answer to your question, no, springs are not an important part of my design. I do, however, believe that the basic OverUnity Principle that drives my Design I could be made more efficient and I suppose it's certainly possible that springs may somehow be used one day to do that.
Darren
