Posted by John Collins (194.164.38.36) on June 12, 2003 at 00:12:10:
In Reply to: Re: John Collins/More posted by David on June 11, 2003 at 17:59:43:
Hi David,
Yes each of the four mechanisms are complete units and they can be removed separately. There will be a bang sound (if it works!) No, I'm not using springs, although I have considered using them to try to reduce lateral movement. In answer to your follow-up post I don't know when it will be finished because when this part is done there may be some minor alterations required to positioning which is easy to do in principle but is fiddly and takes time.
Don't assume that I have the solution as I have been here so many times in the past twenty years that the day I succeed I will probably not notice and will continue to experiment with models.
JC
: Hi John,
: Are these four mechanisms with ten parts complete "units" or do the ten moving parts just happen to sit in the same area? Can they be taken off seperately? Will your machine have the "bang" sound? Are you using springs?
: David
